Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Projectwise Drive + Trend Micro Antivirus freeze PC
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 62 subscribers
    • Views 637 views
    • Users 0 members are here
    • Trend Micro
    • ProjectWise Drive
    • antivirus
    Admin Admin
    Offline Admin Admin over 1 year ago
    Hi.
    If i launch Projectwise drive without Trend Micro Antivirus, Projectwise Drive synchornise correctly prpject.
    If i launch Projectwise Drive with Trend Micro Antivirus, Projectwise Drive freeze PC during 15mn
    I've exclude local path c:\users\*\proijectwise from antivirus path scan, but problem persist.
    I can't disable antivrus,
    Is there another path i have to exclude ? and why PW Drive freeze with Trend Micro Antivirus ?
    Best regards:
    b.tran
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Fri, Dec 9 2022 10:52 AM
      ProjectWise Drive puts stub files on your machine and only populates with the real file from the cloud when accessed. Most likely the anti-virus checking is triggering ProjectWise drive to download all the files and causing the freeze. OneDrive works this way as well so I'm not sure how Trend Micro handles the scenario there. Not sure why excluding the folder doesn't stop the issue, maybe Trend Micro doesn't like wildcards in the middle of a path?
      As to who is responsible to fix, not sure if Bentley didn't implement something for AV where OneDrive did, or if this is a Trend Micro issue.
      As for changing the location of ProjectWise drive, administrators can change this at https://projectwise365.bentley.com
      Documentation:
      Enterprise Administration > ProjectWise Drive (bentley.com)
      I would be careful giving everybody the same path if you have computers where multiple people login at the same time, however you could re-arrange it so the username is last so the exclusion works better. for example: c:\ProjectWiseDrive\%Username% would still give each user their own drive location but you can just exclude c:\ProjectWiseDrive
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Admin Admin
      0 Offline Admin Admin Mon, Dec 12 2022 9:46 AM in reply to Kevin van Haaren
      Hi.
      We are actualy tracking where PW Drive write...
      It seem to write not only in C:\Users\myname\Projectwise,
      PW Drive write lot of files also in :
      C:\Users\btran\AppData\LocalLow
      C:\Users\btran\AppData\Roaming\projectwise-drive
      C:\Users\btran\AppData\Local\Bentley
      C:\Users\btran\AppData\Local\Temp\projectwise-drive
      Antivirus access very often to
      Have you a list of all folder used by PW Drive ?
      Best regards:
      b.tran
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Dec 13 2022 12:18 PM in reply to Admin Admin
      I've never looked into it. Probably have to raise that with Bentley.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Kevin van Haaren
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • goshavol Vol
      0 Offline goshavol Vol Sat, Nov 18 2023 3:17 PM in reply to Kevin van Haaren
      Security is very important, I understand your point, I bought an antivirus myself and my laptop became more efficient. So do not neglect the protection of your device and buy antivirus on which you need, so that in the future do not go to the repair shop or tear down Windows.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
