Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Error 58007 while deleting projects
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 60 subscribers
    • Views 382 views
    • Users 0 members are here
    • PWDI
    • ProjectWise Design Integration
    • ProjectWise
    Bhanu Chauhan
    Offline Bhanu Chauhan 8 months ago
    I need to delete a few projects/work areas in a datasource. But whenever I try to delete a project which contains documents it gives the below error. There are some solutions on the communities but they seem old. I'm part of the Admin group and have the "Show all versions" option ticked for Document List settings.
    Error Information
    Last Error [ 58007 ]
    Error deleting a folder.
    Error deleting a folder. A folder has documents which can not be removed. Remove those documents first.
    Version: 10.00.03.434
    ProjectWise Explorer CONNECT Edition
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Dec 21 2022 7:01 AM
      Does your account have the user setting "use access control" turned on?
      if yes - it's possible there is a hidden file in the folder with permissions set so you can't see the file.
      if no - there is probably an orphan file in the storage area dms folder. You'll have to find the dms folder on the server and delete any orphans (but do NOT delete the folder itself on the server, let pw do that)
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Bhanu Chauhan
      0 Offline Bhanu Chauhan Wed, Dec 21 2022 9:22 AM in reply to Kevin van Haaren
      Yes, my account has "use access control" turned on. What should be the next step? I don't want to manually delete one subfolder at a time for the whole project.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Wed, Dec 21 2022 1:51 PM in reply to Bhanu Chauhan
      Turn off use access control and try deleting the folder again. It will delete files even if you don't normally have permission to see the files.
      If that still doesn't work, somebody will need to login on the server, go to the projectwise storage area, find the dms folder* and delete any orphan files. That will let you delete that one folder, try deleting them all again. If it fails on a different folder you'll have to repeat the process. There is no way to delete orphan files in the storage area.
      * the dms folder number is the folder ID of the folder in ProjectWise if you turn on  the 'Object ID' column in the view you can see it. dms folders are named using that number as follows:
      • folder id <= 99999 folder is named dms#####
      • otherwise folder is named d#######
      • in both cases the number is zero-padded to make the folder name 8 characters long
        • so folder id 349 is dms00349, folder id 123985 is d0123985
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Bhanu Chauhan
      0 Offline Bhanu Chauhan Wed, Dec 21 2022 8:35 PM in reply to Kevin van Haaren
      Thanks for the explanation. Getting the same error upon turning off the "use access control" setting. I don't have any server access. I think I need to reach out to Bentley support.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
