Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Search option keep searching even if canlcelled
    • Sign In
    • State Not Answered
    • Replies 6 replies
    • Subscribers 62 subscribers
    • Views 332 views
    • Users 0 members are here
    Sunil Patil
    Offline Sunil Patil 7 months ago
    Hi Everyone
    When i tried to search a file to attached as a reference file  in a dgn file
    the file keeps searching even if I cancelled the search option as shown in below image
    later i must have to end task the file does anyone has answer to resolve this issue
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Sun, Feb 12 2023 4:13 PM in reply to Sunil Patil +1
      This is a ProjectWise issue. Your admins may have disabled Cancelable Queries, but honestly I've seen this Canceled dialog take forever to dismiss even with cancelable queries turned on. It should eventually…
    • Jon Summers
      0 Offline Jon Summers Fri, Feb 10 2023 3:42 AM
      What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help→About MicroStation in the backstage.
      See this blog that shows you how to obtain MicroStation's version number.
      If you're using an additional product (e.g. ProjectWise, OpenXxx) let us know about that too!
      Regards, Jon Summers
      LA Solutions
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Sunil Patil
      0 Offline Sunil Patil Fri, Feb 10 2023 4:58 AM in reply to Jon Summers
      PW 10.00.03.434
      microstation connect edition : 10.17.02.61
      ORD 10.16.00.80
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Maria Garcia
      0 Maria Garcia Fri, Feb 10 2023 6:47 AM in reply to Sunil Patil
      Hi Sunil,
      If you are trying to attach documents stored in ProjectWise, I suggest you post your issue in PW forum  ProjectWise Design Integration Forum
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Sun, Feb 12 2023 4:13 PM in reply to Sunil Patil
      This is a ProjectWise issue. Your admins may have disabled Cancelable Queries, but honestly I've seen this Canceled dialog take forever to dismiss even with cancelable queries turned on. It should eventually go away but it may take a few minutes.
      Based on the icon set for the search you're doing a full text search. If you're actually searching for a filename or description instead of text inside a file set the search to just search Document and Folder Properties by clicking the magnifying icon then selecting the Document and Folder Properties option. Those searches are much faster.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Sunil Patil
      0 Offline Sunil Patil Mon, Feb 13 2023 11:58 PM in reply to Kevin van Haaren
      thanks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
