Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise can't start MicroStation with desired File (Last Error [222])
    • Sign In
    • State Not Answered
    • Replies 2 replies
    • Subscribers 60 subscribers
    • Views 276 views
    • Users 0 members are here
    • CONNECT Edition
    • MicroStation
    • ProjectWise
    Dirk Buchholz
    Offline Dirk Buchholz 7 months ago
    When loading a dgn file from the ProjectWise database, ProjectWise copies all related references to the c:\pwwork\... Directory, but then throws an error when it tries to call MicroStation:
    "Error Information - Last Error [222]
    Cannot start application for the specified document. Check your program associations. Failed to generate managed workspace configuration file."
    Even when I start ProjectWise with Admin rights the same error occurs.
    The error log pwc.log reports errors like these:
    2023-02-05 18:57:01,571 ERROR [0x00000fcc] pwise.socket - Error -10054 on socket 1644 at func: socket_sendData line: 1368
    2023-02-05 18:57:01,572 ERROR [0x00000fcc] pwise.netapi - Error -11502 "failed to send client request" reported at func: request_sendClientRequest2 line: 621
    Some threads recommend to install PW Administrator and run chklcleanup.exe
    Could that be the solution? (Where do I find the PW Administrator? Is it free to use?)
    How can I solve this problem?
    My Systems are:
    ProjectWise Explorer: Version 100.00.03.49 - Commercial Release
    MicroStation CONNECT Edition Update 17: Version 10.17.02.61
    OS: Microsoft Windows 10 Pro: Version 10.0.19044 Build 19044
    Thank you for your help.
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Online Kevin van Haaren Sun, Feb 12 2023 3:27 PM
      failed to generate a managed workspace configuration means there is an error in the managed workspace config somewhere. chklcleanup is unlikely to fix this. There is a workspace folder in your projectwise working directory for the datasource you can try deleting all the cfg files in that folder, but i suspect this won't fix it either.
      Go to C:\Program Files (x86)\Bentley\ProjectWise\bin\pwc.log.xml and find the line
      <category name="pwise.dms.workspace">       <priority value="warn"/></category>
      change the value="warn" to value="all"
      save the file, then try reopening your file again. The log file may have more hints about the problem after that (you want to look for log messages with pwise.dms.workspace on them instead of pwise.socket like you copied/pasted. Those socket log messages aren't very useful except to Bentley.
      ProjectWise Explorer 10.00.03.49 is a very old version and isn't listed as supported in the version support matrix. Try upgrading to ProjectWise Explorer 10.00.03.453 as well.
      the version support matrix is here: ProjectWise Version Support Matrix (bentley.com)
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dirk Buchholz
      0 Offline Dirk Buchholz Sun, Feb 12 2023 4:43 PM in reply to Kevin van Haaren
      Thank you, Kevin.
      I'll ask my Admin for authorization to install a newer version of ProjectWise.
      Meanwhile, the more verbose log contains the following entries (I hope, this note will not again be flagged as spam and deleted.)
      2023-02-12 22:03:06,672 ERROR [0x0000313c] pwise.dms.workspace - (): With error 32768 failed to expand macro MS_DGNLIBLIST value ''
      2023-02-12 22:03:06,672 FATAL [0x0000313c] pwise.dms.workspace - collectCompiledFileContent(): Failed.
      2023-02-12 22:03:06,676 ERROR [0x00004924] pwise.dms.workspace - Failed to compile configuration files. Compilation failed with aaApi error [32768] and error message [(null)].
      2023-02-12 22:03:06,676 ERROR [0x00004924] pwise.dms.workspace - Failed to create final configuration file.
      2023-02-12 22:03:06,676 ERROR [0x00004924] pwise.dms.workspace - Configuration file generation for the document [39591, 123] failed.
      Does this look like a case for Bentley Support?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
