Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Variable to open specific version of OpenRoads per project?
    • Sign In
    • State Verified Answer
    • Replies 8 replies
    • Subscribers 61 subscribers
    • Views 631 views
    • Users 0 members are here
    mwlong
    Offline mwlong 5 months ago
    With the ability to have multiple version of OpenRoads Designer installed is there any way in ProjectWise to specify which version of ORD is opened? There will be instances where we have older projecs that will not be upgraded to a newer version of OpenRoads. Currently, ProjectWise seems to select the newest version of ORD when you open a file. Is there a way to prevent users from opening a file with a newer release of ORD. I know that a dialog opens stating that the file will be updated if you click OK.
    I was hoping that an Applicaion configuration block could be used but I do not know what variable would be used to select a particular version
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Thu, Apr 13 2023 2:33 PM +2 verified
      Not in a configuration block. You can create application definitions that specify a specific version, then assign that application definition to a file. The trick is to use the version specific Program…
    • mwlong
      Offline mwlong Thu, Jun 22 2023 7:30 AM in reply to mwlong +1
      We had a meeting with our Bentley PW consultant who provided another aspect of this function. If you select your main project folder you can right click on it and select Properties. Select the Resources…
    • Kevin van Haaren
      +1 Offline Kevin van Haaren Thu, Apr 13 2023 2:33 PM
      Not in a configuration block. You can create application definitions that specify a specific version, then assign that application definition to a file. The trick is to use the version specific Program Class Name in the open action.
      Here's the definition i use for OpenRoads 10.11
      When that application is assigned to a file and the user double-clicks the file, ORD 10.11 will be opened automatically. If they right-click and select Open With..., or the default application is not installed, Any installed application that has a matching Open action will be listed in the Open With... dialog and they can pick one of those apps. (The Open With... dialog will also show an option for whatever application is assigned to the file extension this file has. For dgn that'll probably be whatever the last Bentley application that was installed)
      By default you can only set one application to be assigned to files with a specific file extension per datasource and it's annoying to manually assign the application for all files i a project, but if the files are created from a seed file inside the microstation products it will retain the application of the seed file, so you can assign those properly it will help for a project. Additionally users can set which application is assigned to a particular extension when the file is created by going to Tools > Associations > File Extensions... Note this doesn't affect what application is used when the file is opened, just what application is assigned to a new file created in PW.
      Basically we create a generic "Microstation" application that has all the versions listed for all products and we make that the default for .dgn. Then we create version specific application definitions. When we setup a workspace we make sure the seed files are properly assigne to the correct application for that workspace, then if user's ask we show them how to change their association for the .dgn extension to what they want.
      Here are all the version specific Program Class Names I have:
      Application Version Version PCN
      MicroStation All V8i Bentley.MicroStation.Application.{B1E9E1E2-213C-47e5-BDD0-6A528DAE0244}
      MicroStation All Connect Bentley.MicroStation.Application.{39949BF5-7E21-4A7B-A640-6E7199B7D588}
      OpenBridge Modeler V8i SS3 Bentley.OpenBridgeModeler.Application.{8AF1BE9F-A6FD-470D-8ED0-0758ACC9592C}
      OpenBridge Modeler 10.8/10.9 Bentley.OpenBridgeModeler.Application.{81969A98-EDF7-4B21-9D23-7A15482E543F}
      OpenBridge Modeler 10.10.00 Bentley.OpenBridgeModeler.Application.{5C3DC36B-828F-3D8D-AB76-B1510491B515}
      OpenBridge Modeler 10.10.20 Bentley.OpenBridgeModeler.Application.{59AFC35E-CC0C-3943-9947-DFBA383D9A97}
      OpenBridge Modeler 10.11 Bentley.OpenBridgeModeler.Application.{69A810CF-865E-39AD-A727-BAD768EFF32C}
      OpenBridge Modeler 10.12 Bentley.OpenBridgeModeler.Application.{B2BAF2DC-F2FB-3A63-A5FE-18BECD5260AF}
      OpenRail Designer 10.8/10.9 Bentley.OpenRailDesigner.Application.{718972C7-007F-4F72-8AD5-5B0B750E2493}
      OpenRail Designer 10.10 Bentley.OpenRailDesigner.Application.{217410A6-1CD3-383A-A300-1A63A1CF5925}
      OpenRail Designer 10.11 Bentley.OpenRailDesigner.Application.{E4DBA4A0-5F0B-31C8-8206-BB7EC9495183}
      OpenRail Designer 10.12 Bentley.OpenRailDesigner.Application.{1049CC57-E951-3C6B-A4AD-FB24B9FF1D90}
      OpenRoads Designer 10.8/10.9 Bentley.OpenRoadsDesigner.Application.{D11A86DD-FF26-4139-9C79-C1ABB4C8B5BF}
      OpenRoads Designer 10.10 Bentley.OpenRoadsDesigner.Application.{359F376F-B120-3DD3-BC30-56D5687B766D}
      OpenRoads Designer 10.11 Bentley.OpenRoadsDesigner.Application.{B0DCB521-5CE0-3CB5-AD8A-477E98D9B913}
      OpenRoads Designer 10.12 Bentley.OpenRoadsDesigner.Application.{0A1BD8D1-4A49-3D5C-9824-0BC589BE1DEA}
      OpenSite Designer 10.8/10.9 Bentley.OpenSiteDesigner.Application.{7EA0E81E-B260-4808-8921-5C6824F6E48F}
      OpenSite Designer 10.10 Bentley.OpenSiteDesigner.Application.{6C9E6F02-C9CE-3439-BE38-BE20FB1B3795}
      OpenSite Designer 10.11 Bentley.OpenSiteDesigner.Application.{F2103407-E1A1-352E-B57D-469212FB8D8D}
      OpenSite Designer 10.12 Bentley.OpenSiteDesigner.Application.{0FEEB2DB-1678-3DA0-9539-89A662D41850}
      Power GEOPAK V8i SS2 Bentley.PowerGEOPAK.Application.{9B761AD8-C9AB-40F1-BA77-C24AE5B72D18}
      Power GEOPAK V8i SS10 Bentley.PowerGEOPAK.Application.{C6AAA004-FECD-4f5f-8E45-BBDED70BD222}
      Power InRoads V8i SS2 Bentley.PowerInRoads.Application.{593F2B8E-BDEE-490c-B4C3-B48BC356DB91}
      Power InRoads V8i SS10 Bentley.PowerInRoads.Application.{6AADD2ED-E230-47b9-928D-2AC9518B8A8C}
      Power Rail Track V8i SS2 Bentley.PowerRailTrack.Application.{C495A45E-6B0A-411b-AA3B-E327C56D95E4}
      Power Rail Track V8i SS10 Bentley.PowerRailTrack.Application.{6F40A634-F96C-4092-AD64-1E8AF69F47D4}
      Answer Verified By: mwlong
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • mwlong
      0 Offline mwlong Fri, Apr 14 2023 7:23 AM in reply to Kevin van Haaren
      Kevin van Haaren
      Thanks for the information. I have not had time to fully digest this information but I will go over this with our PW Administrator and discuss this option. I have one question. I believe I have found the location to set this up. In PW Admin I go to <Datasources <Datasource <Applications. In the pane I see OpenRoads Designer. When I select that, right click, select Properties. Now I see the dialog like the screenshot you posted.
      This is where I add the various version specific Class Names?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • mwlong
      0 Offline mwlong Fri, Jun 9 2023 9:08 AM in reply to Kevin van Haaren
      I finally had a chance to work on this. Your method works. I wish there was a way to apply it to an entire project rather per file.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mark Shamoun
      0 Mark Shamoun Sat, Jun 10 2023 12:07 AM in reply to mwlong
      What about editing your Work Area Resources to change the Application list to the new version specific ones?
      Mark
      OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023  |  ProjectWise CE 3.4
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Sat, Jun 10 2023 12:07 PM in reply to Mark Shamoun
      That lets you change what applications are available in the application drop down for files in the project, but doesn’t let you change what an extension maps to in that project.
      I don’t remember what happens when you drag a dgn file into a project that does not have the application with the dgn extension in its resources. I want to say it assigns the default anyway, but it may assign the no application instead.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
