Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Variable to open specific version of OpenRoads per project?
    • Sign In
    • State Verified Answer
    • Replies 8 replies
    • Subscribers 61 subscribers
    • Views 619 views
    • Users 0 members are here
    mwlong
    Offline mwlong 5 months ago
    With the ability to have multiple version of OpenRoads Designer installed is there any way in ProjectWise to specify which version of ORD is opened? There will be instances where we have older projecs that will not be upgraded to a newer version of OpenRoads. Currently, ProjectWise seems to select the newest version of ORD when you open a file. Is there a way to prevent users from opening a file with a newer release of ORD. I know that a dialog opens stating that the file will be updated if you click OK.
    I was hoping that an Applicaion configuration block could be used but I do not know what variable would be used to select a particular version
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Thu, Apr 13 2023 2:33 PM +2 verified
      Not in a configuration block. You can create application definitions that specify a specific version, then assign that application definition to a file. The trick is to use the version specific Program…
    • mwlong
      Offline mwlong Thu, Jun 22 2023 7:30 AM in reply to mwlong +1
      We had a meeting with our Bentley PW consultant who provided another aspect of this function. If you select your main project folder you can right click on it and select Properties. Select the Resources…
    • mwlong
      0 Offline mwlong Tue, Jun 13 2023 6:28 AM in reply to Kevin van Haaren
      Kevin van Haaren
      I seem to have run into an issue with this method. Working in a client's datasource, they use ORD 10.11 (2022 R1) currently. They have a vba that runs upon opening a file which checks for the ORD version. If it does not match ORD 10.11 it will not open the file. I applied my ORD 10.11 Application to a file (we are helping them update their workspace to ORD/CONNECT so I have Admin privileges). When I double click on a file in PWE I receive the dialog stating the version attempting to open the file is not 10.11. If I right click on the file and select Open With & browse to the 10.11 OpenRoadsDesigner.exe the file opens.
      Do you think something with that vba module is causing the issue?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • mwlong
      0 Offline mwlong Tue, Jun 13 2023 10:32 AM in reply to mwlong
      I think I found what the issue was. Under <Tools <Associations <User my ORD version was not set correctly for 2022 R1. It was set to use 2022 R3. Making that correction I am able to apply the application to a file and it opens with the correct version.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • mwlong
      0 Offline mwlong Thu, Jun 22 2023 7:30 AM in reply to mwlong
      We had a meeting with our Bentley PW consultant who provided another aspect of this function. If you select your main project folder  you can right click on it and select Properties. Select the Resources tab and verify the Resource Type is set to Application.
      Scroll down to the versions of ORD and select the ones you are not using for the project, then select Remove.
      This removes the ORD versions from the list available if a user tries to right click on a file and selecting Open With.
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
