Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum How to renumber a drawing in ProjectWise to a drawing number that has already been used for a drawing that was issued but is now withdrawn?
    • Sign In
    • State Suggested Answer
    • Replies 3 replies
    • Answers 1 answer
    • Subscribers 59 subscribers
    • Views 227 views
    • Users 0 members are here
    • Projectwise Numbering
    Henry Metcalf
    Offline Henry Metcalf 4 months ago
    A large set of drawings were prepared and issued but it was then spotted that some of the drawing numbers were wrong. We now need to renumber some of the drawings, however, Projectwise will not let us assign a drawing number if that drawing number was previously used by another drawing (even though that drawing is no longer used/withdrawn/has been given a new number itself!). It is almost like Projectwise has 'blocked' the use of any drawing number if that number has been historically used.
    • Sign in to reply
    • Cancel
    • Stephan Searles
      0 Offline Stephan Searles Tue, May 9 2023 3:00 PM
      If you used Document Code to generate your number, what happens if you clear the code before you try to renumber something else to the desired number?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • David Nicholson
      0 Offline David Nicholson Tue, May 9 2023 6:47 PM
      Once a document using a document code is versioned, the document code is also transferred to that version.  Removing the document code from the active version does not remove the document code from the previous versions, as all attribution in the version(s) become read-only.
      In our experience, the only available options are:
      1. Remove all previous versions of the document (undesirable)
      2. Export all versions of the document using the Import/Export tool, modify the document code attribute (and any attributes that were used in creating the document code), and then import the changes, updating the attribute fields (messy & error prone)
      Document code is a great feature and does exactly what it's designed to do - ensure document naming uniqueness.  But it's tedious to manipulate once versions are generated.
      HTH
      Regards,  David
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Henry Metcalf
      0 Offline Henry Metcalf Fri, May 12 2023 3:10 AM
      Thank you Stephan and David for your responses.
      I think there is a potential solution. The 'Document Code' created for a drawing in Projectwise is locked out of use permanently once it has been assigned to a drawing and this can not be changed, however, we can change the 'Client Document Code' (that is what external audiences would see) as we see fit. This would solve the problem for all external audiences/clients/people and they would not know the 'Document Code' is different to the 'Client Document Code'.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
