Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Local Network worksets to ProjectWise
    • Sign In
    • State Not Answered
    • Replies 4 replies
    • Subscribers 61 subscribers
    • Views 171 views
    • Users 0 members are here
    Francisco Garcia
    Offline Francisco Garcia 5 months ago
    after a workset is created in the network and now the project need to be in ProjectWise, is it ok to just drag and drop the workset/project folder and config file and dgnws to their respective folder in ProjectWise?
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Mon, May 8 2023 3:57 PM
      Without a managed workspace your DGNWS & workset configuration won't work in ProjectWise.
      You'll also need to do a scanref to fix the reference file attachments for all your dgn files.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Francisco Garcia
      0 Offline Francisco Garcia Mon, May 8 2023 4:42 PM in reply to Kevin van Haaren
      Managed workspace has been set up, just didn't know if i needed to create the workset(New Workarea) and dngws from PW or can i just drag and drop, project was started out of PW and need to move it. Right i will need to scan for ref, i also thought there was another program/app to transferee files to PW from local or network drives. thanks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Mon, May 8 2023 4:48 PM in reply to Francisco Garcia
      If the workset name is the same i think you can use the dgnws. it the workset name is different the dgnws will display the old name in the Project Explorer and may have some odd issues. If it has sheets in the sheet index already I'm not sure how they'll work in projectwise, i haven't tried it. Not sure a scanref will fix sheets in the sheet index, but it may not need too.
      drag and drop is the easiest way to get the files in, there isn't another app. If it's a really large amount of data it might be better to first copy it to your local computer and then drag and drop into ProjectWise. Really big transfers will sometimes abort. Doing it in pieces can also help.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Francisco Garcia
      0 Offline Francisco Garcia Mon, May 8 2023 4:55 PM in reply to Kevin van Haaren
      Kevin, thanks a lot for your help. The workset will be the same name, there are no sheets in the index. thanks for the tip for copying to local computer, thanks again, Flg
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
