Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Adding a new Attribute to an existing document code
    • Sign In
    • State Verified Answer
    • Replies 2 replies
    • Subscribers 60 subscribers
    • Views 163 views
    • Users 0 members are here
    Luc Poulin
    Offline Luc Poulin 4 months ago
    Hello
    In my continue effort  to get skill at manipulating the Environments...
    I wanted to add an attribute to an exciting document code.
    I create the necessary attribute (FI_Activity_Code) under the same environment as all the other attributes that compose the Document Code and matching other attributes properties. Like Vchar etc....
    I edit the Document Code definition and add this new attributes at step one and move to the end of the  wizard to move up that new attribute to its position.
    When I click Finish i get this....
    I'm not sure what are those required fields???
    • Sign in to reply
    • Cancel
    Top Replies
    • Anderson Mancebo
      Offline Anderson Mancebo Tue, May 16 2023 9:10 AM +1 verified
      Hi Luc, When you create a new attribute, it will be a column in the Environment Table. It means that you have created a empty column (FI_Activity_Code) for all documents that have a sheet (row in this…
    • Anderson Mancebo
      +1 Offline Anderson Mancebo Tue, May 16 2023 9:10 AM
      Hi Luc,
      When you create a new attribute, it will be a column in the Environment Table. It means that you have created a empty column (FI_Activity_Code) for all documents that have a sheet (row in this table) in this Env.
      You have two ways to work with this:
      1. You can check (in document code) to "Allow empty value" for this attribute.
      2. Before add this to your Document Code, make a search for all documents in this environment and change the value of this attribute (FI_Activity_Code) for, i.e, "-". Then add the attribute as you need in you Document Code. And you don't need to check the option to allow empty value.
      I hope it helps!
      Answer Verified By: Luc Poulin
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Luc Poulin
      0 Offline Luc Poulin Tue, May 16 2023 2:22 PM in reply to Anderson Mancebo
      Anderson Mancebo
      Thank you, the Allow Empty Value was not check, Rookie mistake...
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
