Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Error 58218 - The checkout location is already in use.
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 8 replies
    • Subscribers 62 subscribers
    • Views 749 views
    • Users 0 members are here
    • Projectwise Explorer
    • error 58218
    DshannonNTM
    Offline DshannonNTM 6 months ago
    We are using ProjectWise explorer version 10.00.03.453 and logging into another companies server to work.
    ONE user on ONE computer cannot open a couple files they created 2 years ago.
    If he remotes into another machine, he is able to open it. We searched and found information here:  Using the CHKLCLEANUP Utility in ProjectWise [TN]
    but this file does not exist on anyones machine at our company...
    So far we have tried uninstalling PW and deleting the working directory on the c drive to no avail. IT has to be storing old information somewhere on this machine.
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Thu, May 25 2023 4:41 PM +2 verified
      Somebody should have ProjectWise Administrator installed on their machine, whoever admins your projectwise should have it. chklcleanup.exe is installed with that. Running chklcleanup.exe requires projectwise…
    • DshannonNTM
      Offline DshannonNTM Fri, May 26 2023 8:04 AM in reply to Kevin van Haaren +1
      We only have ProjectWise Explorer as we are a smaller subconsultant. The ProjectWise Administrator would need run on the server where PW data is held, correct? If so, I will forward this response to the…
    • DshannonNTM
      0 Offline DshannonNTM Mon, Jun 26 2023 12:37 PM in reply to Dave Cumming
      We did that and still are having issues. We uninstalled all Bentley and are still having issues. The only option left is to completely rebuild machine.
      We have contacted the Prime consultant who owns/runs the PW server and are waiting to hear back from them.
      thanks!
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dave Cumming
      0 Offline Dave Cumming Tue, Jun 27 2023 6:37 PM in reply to DshannonNTM
      It sounds like your Prime Consultant should be the person who is able to use the chklcleanup utility to clear the issue for you, referring to what Kevin mentioned in his post last month.
      The PW database is looking at the PC name, so rebuilding it isn’t necessarily going to help in this case.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • DshannonNTM
      0 Offline DshannonNTM Tue, Jun 27 2023 6:59 PM in reply to Dave Cumming
      Thanks Dave. We have reached out to them and are waiting for a response. We did find an interesting work around…. If the designer(s) who are having the issue on there specific machine uses my PW login or any other persons login, the file opens. This designer can also log into any other computer and use their own log in, it also works. It’s a really weird scenario.
      our temp with around is for those 2 designers to switch PW logins.
      I will respond with a post once the Prime gets back to us and if we ever figure out the issue.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
