Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum MicroStation 2023 & ProjectWise
    • Sign In
    • State Not Answered
    • Replies 1 reply
    • Subscribers 60 subscribers
    • Views 200 views
    • Users 0 members are here
    Kevin van Haaren
    Offline Kevin van Haaren 2 months ago
    MicroStation 2023 was released yesterday, it can be side-by-side installed with MicroStation Connect (and V8i) which means.... new Program Class Name.
    Originally when the MicroStation 2023 FAQ was released it indicated only ProjectWise 2023 (no sign of that being released) was certified, however the FAQ has been updated to indicate PW 10.00.03.453 and PW 10.04.02.44 (I've not seen this version either, presumably a beta for PW 2023?) and PW 2023 are certified. The installed detects if ProjectWise 10.00.03.453 are already installed and automatically integrates with it if it is. I presume it does the same for the other certified versions.
    MicroStation 2023 Frequently Asked Questions - MicroStation Wiki - MicroStation - Bentley Communities
    I don't see anything that might break your managed workspaces, but I also haven't tested this yet. It does have a different config directory so if you modify the ConfigurationSetup.cfg and other delivered workspace files they are in C:\ProgramData\Bentley\MicroStation 2023\Configuration now.
    The new program class name for MicroStation 2023 is:
    Bentley.MicroStation.Application.{6B0254D4-D37F-318A-BB2D-83924E8EAD88}
    So you can setup a MicroStation application that explicitly lists each installed version when using Open With..., or set the default to your preferred version. Just create Open actions for each version and set the Program Class Name to the appropriate one.
    See also:
    [PW Explorer] Force Default Program at Work Area Level - ProjectWise Design Integration Forum - ProjectWise - Bentley Communities
    ProjectWise Open document with dialog box - ProjectWise Design Integration Forum - ProjectWise - Bentley Communities
    Note that during installation you can change the install options and turn of "File association" in the Application Options and it will not take over the .dgn (and .dgnlib and .dgnws and etc...) extension from whatever is currently associatied with it.
    • Sign in to reply
    • Cancel
    • Matt Bombace
      0 Offline Matt Bombace Mon, Jul 3 2023 6:27 PM
      Thank you Kevin van Haaren
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Matt Bombace
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
