Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Thumbnail and File Property Extraction
    • Sign In
    • Replies 2 replies
    • Subscribers 59 subscribers
    • Views 2495 views
    • Users 0 members are here
    • v8i
    • ProjectWise
    • document processor
    Sean Keene
    Offline Sean Keene over 14 years ago
    Can I change the directory where the Thumbnail and File Property Extraction copies documents for processing?
    I have a server that is on VM Ware with a small C: drive allocation and I had to reprocess some projects which filled up the C: drive and caused just a small problem (no one could login).  Instead of allocating more C: drive space I would like to tell ProjectWise to use a different location to store the docs for Thumbnail and File Property.
    I am assuming that this is possible and also that ProjectWise makes a temporary copy of the document for process and then deletes the copy after process is complete.
    Any help would be appreciated!
    TIA
    Sean Keene
    • Sign in to reply
    • Cancel
    • Stephen Herrick
      Stephen Herrick Wed, May 27 2009 3:23 PM
      Hello Sean,
      Starting with build 8.9.3.49 it possible to specifically set where Automated File Processors will put the temp files. You do that by adding a string value ExtractionTempDir under the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Bentley\ProjectWise\Automated File Processing  and specify a valid path as a value, say: d:\afp-temp
      HTH
      Stephen,
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Sean Keene
      Offline Sean Keene Thu, May 28 2009 12:42 AM in reply to Stephen Herrick
      Stephen
      I appreciate your response and that worked perfectly.
       Sean
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
