Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Default location for document templates
    • Sign In
    • Replies 6 replies
    • Subscribers 61 subscribers
    • Views 5941 views
    • Users 0 members are here
    • ProjectWise
    • Document Templates
    Sean Keene
    Offline Sean Keene over 14 years ago
    Either I cannot find this option or it does not exist.
    I am looking for the option to set a path in PW for document templates.  I am using the Advanced Wizard for document creation and would like it when I select a PW document as a template that path be pre-determined.  If my memory serves me right I thought this is an option, but of course my memory could be wrong.
     Anyone?
    TIA
    Sean
    PW 08.11.05.37
    • Sign in to reply
    • Cancel
    • Edita Kemzuraite
      Offline Edita Kemzuraite Thu, Jul 30 2009 11:04 AM
      Hello Sean,
      As far as I know there are three possibilities to select document templates using the Advanced Wizard:
      1. To create a new document based on an existing ProjectWise document, turn on Use ProjectWise document as a template, click Select, and select a document from the Select Template Document dialog. If you are dragging an existing ProjectWise document from one folder to another, this option and the document you are dragging over will be selected by default.
      2. To create a new document based on a file not currently stored in ProjectWise, turn on Use external file as a template, click Browse, and select the external file to use as your seed file. If you are dragging a file in from Windows Explorer, this option and the file you are dragging in will be selected by default.
      3. To create a new document by using a file or document that has already been used by the wizard to create a new document, turn on Select from recent used templates and select the file or document to use from the list. This option is disabled if this is the first time using the wizard.
      I think, the third case would be the answer to your question. In such way it is possible to use already pre-determined path. Or do you want to do something else?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Sean Keene
      Offline Sean Keene Thu, Jul 30 2009 1:13 PM in reply to Edita Kemzuraite
      Edita,
      Thanks for the explanation, but I already know how to use the Advanced Wizard.
      I am asking if there is an option to tell ProjectWise Explorer to use a specified path for a document template either with a variable or with ProjectWise Admin.  As an example, in MicroStation there is a variable called MS_DESIGNSEED that allows a person to set a path that will always select the correct seed file for MicroStation to create a new drawing.
      In ProjectWise Explorer if I create a new document based upon an existing ProjectWise document, I would like to set the path ProjectWise Explorer goes to when I click Select.  A pre-determined path.
      Is there a variable or some other way to set the path?
      Sean
      • Cancel
      • Sign in to reply
      • Cancel
    • Stephen Herrick
      Stephen Herrick Thu, Jul 30 2009 3:56 PM in reply to Sean Keene
      Sean,
      I believe what you are needing has already been filed as a Change Request (cr 225669)
      The change request states that a template folder can be configured in ProjectWise administrator to a certain folder location so when the user selects, from the Document Creation Wizard, "Use ProjectWise document as a template" and they select browse a predetermined folder would open with all the available templates.  In your MicroStation scenerio the one variable for dgns could work, but as many differnt types of files will be created have a central folder with all available templates would fix your issue as I understand it.
      As you already seen when you add a document as a template it is stored in the "Select from recent templates"  This information is stored in the pwv8.brg file.  So if your goal is to have everyone use the same template when creating files, you could go through the steps of creating the files, that would then populate the recent file area, you could then copy the pwv8.brg file to all of your users, this isn't as elegant as have the template predefined, but it could be a viable workaround.
      As another note you can view the contents of the pwv8.brg file using the ProjectWise registy editor which is in the program group Administrative Tools
      One more item, the pwv8.brg file is located in the users Document and settiings for example
      C:\Documents and Settings\stephen.herrick\Application Data\Bentley\ProjectWise\Config\pwv8.brg
      Stephen,
      • Cancel
      • Sign in to reply
      • Cancel
    • Johannes Paulus Visagie
      Offline Johannes Paulus Visagie Mon, Aug 23 2021 4:45 AM in reply to Stephen Herrick
      Good day
      This seems like a very old conversation and I am sure that (cr 225669) is resolved. Where will we find the final procedure to this request?
      Senior Highway Design
      ZUTARI SOUTH AFRICA & AURECON
      • Cancel
      • Sign in to reply
      • Cancel
    • Ray Lucas
      Offline Ray Lucas Thu, Sep 16 2021 5:56 PM in reply to Sean Keene
      Yes I was looking for the same thing, was the change request done.  We have this for Work Area's seems logical to have a document template folder that can be used as a selectable drop down list for Documents in the new documents dialog.
      Shell Australia
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
