Projectwise Web Server Login Page
Ive noticed a few companies have a generic login page to gain access to the bentley web server (WEL Client) that looks to have a web part used for logging in.  We just installed V8i Select Series 1 and I see no such web parts.  Can someone point me in the right direction or help me find a templage page or whatever is being used for this logon web part.  Attached is a screen shot from carrollo's website showing the logon screen.  Thanks
  • Hi,
    Can you be a little more specific on what you're trying to accomplish?
    I assume you have ProjectWise Web Parts installed/configured on a NON-SharePoint Server, and if you hit the Login link that it works?
    If so, you could modify the default.aspx page such that you automatically login using Single Sign-on, and eliminate the login process altogether.
    If you can elaborate on the ideal behavior, we can probably get you headed in the right direction.
    Best Regards,
    Gary
Reply
  • Hi,
    Best Regards,
    Gary
