Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Increasing Length value for character data types
    • Sign In
    • Replies 10 replies
    • Subscribers 61 subscribers
    • Views 5715 views
    • Users 0 members are here
    Sultan Sadique
    Sultan Sadique over 13 years ago
    Dear All
    I want to increase the length value of one attribute in PW admin(08.11.05.37),How to do this?
    TIA
    • Sign in to reply
    • Cancel
    • Ian Emery
      Offline Ian Emery Sun, Apr 25 2010 6:38 PM
      Dear Sultan,
       Options
      (1) Delte the attribuite and recreate it. - be aware this will remove all existing values and change the docuement number  configuration if it is used there too. - Becareful
       (2) Contact TSG - I believe the value can be changed by manually editing several places in the Projectwise database.
      Best regards
      Ian Emery
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Sultan Sadique
      Sultan Sadique Mon, Apr 26 2010 7:55 AM in reply to Ian Emery
      Dear Ian
      Its not possible to delete the attriubute because we have  tens of thousands of files.I tried manually increasing the length of the attribute in database but its not working when i update that attribute in PW Explorer with more characters.
      Sultan
      • Cancel
      • Sign in to reply
      • Cancel
    • Ian Emery
      Offline Ian Emery Mon, Apr 26 2010 8:40 AM in reply to Sultan Sadique
      Dear Sultan,
      The editing the database definition for the attribuite is not enought  - as you have seen. The column definition is cached in another table too.
       Editing your database directly like this is a "not supported action" - TSG is probablay you safest route.
      Best regards,
      Ian Emery
      • Cancel
      • Sign in to reply
      • Cancel
    • Marty.Nickel
      Offline Marty.Nickel Mon, Apr 26 2010 4:40 PM
      Sultan,
       Unfortunately there is no easy way to increase the size of an attribute, as Ian stated the easiest way would be to create a new attribute.  When it comes to altering your database, this does put you in an unsupported environment, so as a TSG Analyst I would highly suggest against altering your database.  The best way for you to go about this would be to either 1. create a new attribute and migrate the data over or 2. contact Bentley Professional Services to help increase your attribute size.
      Marty
      • Cancel
      • Sign in to reply
      • Cancel
    • Kevin van Haaren
      Offline Kevin van Haaren Tue, Apr 27 2010 10:43 PM
      As others have mentioned the length is stored in several database tables and you really don't want to mess with it.
       My procedure is:
      • Create a new attribute matching the old called TEMP (in pw admin app)
      • In the database use SQL to copy the values from the old attribute to the TEMP attribute
      • Delete the old attribute (in pw admin app)
      • Create a new attribute with the same name as the old attribute but with the new length you want (in pw admin app)
      • Use SQL to copy the values from the TEMP attribute to the new, with correct length, attribute
      • delete the TEMP attribute. (in pw admin app)
      PRACTICE THIS IN A DEV DATASOURCE BEFORE DOING IT FOR REAL!
      HAVE A BACKUP OF YOUR DATABASE BEFORE BEGINNING.
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
