Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Unable to handle multiple sheet drawings .. ?!
    • Sign In
    • Replies 28 replies
    • Subscribers 61 subscribers
    • Views 18798 views
    • Users 0 members are here
    • sheets tags
    Mikkel Bennedbaek
    Offline Mikkel Bennedbaek over 12 years ago
    Hi There!
    I was just wondering when it would be possible to handle multiple title blocks in dgn files with multible sheets?
    It is common to have the same title block  tag set in several sheets but as far as I know, ProjectWIse can only handle one (or all as it was one).
    This would of cause require one unique id for each sheet (besides of the document id) and a corrosponding atrribute page for each sheet, but it would be a great improvement! (No need for more than one attribute page in the dialog - instead there should be "Next sheet"- /  "Previous sheet"- buttons in that!)
    Sheet names could be added to the tag name in ProjectWise so they would maintain unique for ProjectWise and the db, eg.: SHEET1|drwdate, SHEET2|drwdate, ...
    Please let me know if aboe is all rubbish an nonsense to you guys .. :)
    Re
    Mikkel
    • Sign in to reply
    • Cancel
    Top Replies
    • shenry
      Offline shenry Sun, Mar 20 2011 11:29 PM +2
      I would also like to see this functionality included with ProjectWise. Requested it eight years ago, and our Bentley rep documented the solution. Looked like it was going to be incorporated but then..…
    • @B, Carl Broyles
      Offline @B, Carl Broyles Wed, Jan 24 2018 10:34 AM in reply to Jeff Burrill +2
      It should be a TR - 7 years 12,464 views, 26 replies, no solution? Any file can have multiple attribute "sheets". This concept has been in ProjectWise since forever. But we have never had a way to utilize…
    • David Keam
      David Keam Mon, Mar 21 2011 2:19 AM in reply to Scott Turner +1
      I believe this is a significant oversight by Bentley. Multiple models have been part of the dgn file format since V8 and that's a long time. InRoads has been generating multiple cross-section sheets in…
    • Scott Soper
      Offline Scott Soper Thu, Mar 24 2011 3:10 PM in reply to David Keam
      At WSDOT, we have used multiple sheet files since we began with Intergraph.  We currently have the ability to automatically place up to 40 sheets in a file.
      When we began using ProjectWise in 2005 we realized that in order to integrate attributes we would need to move to single sheet per file.  This was not meet with enthusiasm by our users.
      Now, due to other factors, we are looking at single sheet files again, but I still think it would be advantageous if we had the option to apply attribute integration to multiple sheet files.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Mikkel Bennedbaek
      Offline Mikkel Bennedbaek Sun, Apr 3 2011 10:43 AM in reply to Dean Lyon
      We are often having 20 sheets or more in each plotfile. As there is about 30 or more tags in each title block (depending on the number og revision lines which varies), I would need to find space for over 600 titleblock text fields in the attribute dialog. Even if I used fontsize 6px or smaller, that would not make room enough... :)
      Besides, (it is not very importent, but...) if you are using the same TagSet on several sheets in same file, I think only on of them will update the database from the titleblock when using the update key-in... ?!
      • Cancel
      • Sign in to reply
      • Cancel
    • Mikkel Bennedbaek
      Offline Mikkel Bennedbaek Sun, Apr 3 2011 11:22 AM
      Hi again! At least great to know that I am far from alone struggling with this issue :)
      Just to keep you all informed...
      I made a CR on this some time ago, but last week a had a remote session with Jutin Jussal from Bentley where I descriped the issue/wish in details supported by example file / illustration.
      When he gets back to me I will remember to keep you guys all informed, but meanwhile I recommend that you also submit CR's, as I am not sure that Bentley realy understands how what great improvement that support for multible sheets in ProjectWise would be... :)
      You will here from me soon...
      Mikkel
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Cancel
    • Scott Soper
      Offline Scott Soper Mon, Apr 4 2011 9:24 PM in reply to Mikkel Bennedbaek
      If you give us the CR number we can add our names to it.
      • Cancel
      • Sign in to reply
      • Cancel
    • Mikkel Bennedbaek
      Offline Mikkel Bennedbaek Tue, Jul 5 2011 12:53 PM in reply to Scott Soper
      CR 319918: User wants PW to work on DWG projects where several sheets in one file are used
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
