Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Process PW dgn file silently
    • Sign In
    • Replies 17 replies
    • Subscribers 60 subscribers
    • Views 8378 views
    • Users 0 members are here
    ttl
    ttl over 12 years ago
    Is it possible to use a dos command to run MicroStation V8i SS1 batch process on a DGN file in PW using Single Sign On?  I mean automated thing without user intervention.
    TIA
    • Sign in to reply
    • Cancel
    • Dean Lyon
      Offline Dean Lyon Thu, Jun 2 2011 1:33 PM
      It is possible to write a PW API program that would login SSO, then check out a file or files, then run a process on each file, then check them back in and log out.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Michael McCarty
      Michael McCarty Thu, Jun 2 2011 10:53 PM in reply to Dean Lyon
      Sure. The APIs from aaapi.h and aadmsapi.h are non-GUI, and can be used to write console or batch applications that interact with ProjectWise.  On the other hand, we ship the Orchestration Framework with the product, which already supports everything you need, and will be more scalable, as well as providing a certain level of fault tolerance and retry capability.
      • Cancel
      • Sign in to reply
      • Cancel
    • Dean Lyon
      Offline Dean Lyon Fri, Jun 3 2011 1:31 PM in reply to Michael McCarty
      I have never used Orchestration Framework to process document files, outside of the predefined uses.  Where would I find the documentation?
      • Cancel
      • Sign in to reply
      • Cancel
    • Kevin van Haaren
      Offline Kevin van Haaren Fri, Jun 3 2011 3:51 PM in reply to Dean Lyon
      I'm interested in this as well. Hadn't ever thought of this.
      • Cancel
      • Sign in to reply
      • Cancel
    • ttl
      ttl Sun, Jun 5 2011 10:45 PM in reply to Kevin van Haaren
      Michael,  Any examples/further illustrations as to how to run in command prompt or Orchestration Framework?  So far I can only do it if and only if MicroStation app is itself running to launch the vba console and run PW API's, how do I do it  with MSTN app running in background/Windows scheduled tasks to process a PW file?
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
