Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Personal Views in ProjectWise Explorer SS1 & SS3
    • Sign In
    • Replies 3 replies
    • Subscribers 60 subscribers
    • Views 3678 views
    • Users 0 members are here
    mvallee
    mvallee over 12 years ago
    Hi all,
    I'd like to report what could be a bug in ProjectWise Explorer SS1 & SS3, or at least I think so...
    As a normal user I create a personal view (View -> Manage View) called Test_view while for instane the focus is on Project A.
    But when I select some other projects or folders (let's say project B for instance), this personal view disappears from the View list, so I can't temporarily choose that personal view ! The only way to apply Test_view to Project B is to modify Test_view by specifying that it's the default view for Project B, but it's not what I want !
    What is weird is that on those particular projects, it is also not possible to select the global views I created as an admin.
    If anyone has an idea...
    Thanks a lot.
    • Sign in to reply
    • Cancel
    • Stephen Herrick
      Stephen Herrick Wed, Aug 3 2011 5:52 PM
      Check your Project Resources, if it is not defined as inherit, only the selected views will be available for that project
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • mvallee
      mvallee Thu, Aug 4 2011 9:17 AM in reply to Stephen Herrick
      Thanks a lot, that's the solution... Is there a way as an admin to define the View Resources as "Inherit" for all the projects in one click, and to set it to this value by default ?
      • Cancel
      • Sign in to reply
      • Cancel
    • Stephen Herrick
      Stephen Herrick Mon, Aug 8 2011 3:12 PM in reply to mvallee
      By default when you create a Project it inherts everything by default.  You will need to modify each project seperatley.
      • Cancel
      • Sign in to reply
      • Cancel
    Reply
    • Stephen Herrick
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
