Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum unmanaged workspace
    • Sign In
    • Replies 1 reply
    • Subscribers 58 subscribers
    • Views 1817 views
    • Users 0 members are here
    unmanaged workspace
    Michael J. Madrid
    Michael J. Madrid over 12 years ago
    We have run into too many issues with managed workspaces that we are flirting with unmanaged workspaces.  We have a handful of projects that are unmanaged.  We have subfolders in these projects that we kept managed for subs & clients.  I am trying to get the unmanaged W/S configured for external users and I have run into an issue.  MS will crash without giving any informatio what caused the crash.  We have the Root directory set to a UNC (e.g. \\server\share\) in the unmanaged profile.  I then set -wsC:\CADD\external.cfg in the additional command-line arguments.  I ran a debug and the config file is being read.  When I remove the debug, I get a crash.  Any help is greatly appreciated.
    • Sign in to reply
    • Cancel
    • jrathkey
      Offline jrathkey Thu, Aug 25 2011 1:52 PM
      Unmanaged Workspaces passes all the configuration settings on the command line to launch MicroStation.  If it crashes through ProjectWise with a specific command line it will more than likely crash from straight MicroStation.  The local workspace configuration needs to work for the unmanaged workspace to work.  What I would recommend is to use a program (i.e. Process Explorer) to capture the command line used to launch MicroStation from ProjectWise.   Go to a windows command shell and run the command line.  MicroStation should still fail but it might write something to the command window as to why, give you some direction to troubleshoot.  If it doesn’t help you can try eliminating pieces of the configuration until you find the parameter that is causing the failure.   If that doesn’t help I would recommend contacting the Technical Support Group.
      Jeff
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
