Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum How to turn off Datasource prompt in AutoCAD?
    • Sign In
    • Replies 2 replies
    • Subscribers 58 subscribers
    • Views 10496 views
    • Users 0 members are here
    • Turn off
    • remove
    • AutoCad
    • datasource
    • ProjectWise
    Life of Ryan
    Offline Life of Ryan over 11 years ago
    Hi All,
    I searched high and low for an answer to this, but no luck. We installed PW Explorer on several PCs for use on a project with MicroStation. Unfortunately, PW has ingratiated itself with AutoCAD 2010/2011 as well, causing confusion and delay (It really should ask politely upon install which applications it is to be associated with, not surprise everyone).
    We can turn off the Datasource prompt in MicroStation using -wsProjectWise_Integration=1 on the command line. What is the equivalent in AutoCAD? And not just turn off the Datasource prompt, but remove the ProjectWise tab and any other remnants as well.
    TIA,
    LOR
    • Sign in to reply
    • Cancel
    • Vickie Ramsey
      Offline Vickie Ramsey Mon, Mar 5 2012 3:46 PM
      When you are installing the ProjectWise Client, select Custom Install and there is Custom Setup a page that shows what is being installed in tree form. If you expand the idesktop integration branch, then expand the AutoCAD branch you can select specifically which AutoCAD version to integrate. You can open Control Panel\All Control Panel Items\Programs and Features and uninstall the integration that you don't wish to use.
      IN the registry you can set a key that will stop ProjectWise from redefining the commands. You can also key in DMSOFF at the commandline to disable integration.
      But if you truly do not want any of the integration pieces the best thing is to uninstall integration for that version and then repair AutoCAD 2010.
      Victoria Hewitt
      Bentley Technical Support
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Life of Ryan
      Offline Life of Ryan Mon, Mar 5 2012 9:37 PM in reply to Vickie Ramsey
      Got it thanks. The key-in will do for now.
      LOR
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
