Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Performance - Caching Server
    • Sign In
    • Replies 11 replies
    • Subscribers 58 subscribers
    • Views 7729 views
    • Users 0 members are here
    • ProjectWise
    • Caching Server
    Bob Hanson
    Offline Bob Hanson over 11 years ago
    We have been experiencing delays in Checking out and checking in files, exporting files, etc where the transfer dialog sits there like nothing is happening for an average of about 1 min.  These delays seem to be approximately every 10 min.  The caching limit has been reached and it appears that a process is running (purge pass?) to scan for the oldest files to be purged out.  We are using the default purgebatchsize value of 1000 files.  We noticed that when the purge pass is running it seems to pretty much take up all the resources of the server or brings it to a stop for a period of time.
    VM Server 2003 SP 2 Standard Editions
    Intel Xeon CPU, X5650 @ 2.67 GHz, 2.66. GHz, 2.00 GB of Ram
    ProjectWise Caching Server (SELECTseries 3) v08.11.09.091
    Cache section in dmskrnl.cfg on caching server
    [cache]
    Enabled=True
    StoragePath = e:\ProjectWiseCache
    Limit = 8000
    Server statistics – 6.35 gb used under e:\ProjectWiseCache\files, 5,616 files in 34,011 folders (as of 7:30 am CDT 06-21-2012)
     Questions:
    1. Does this sound like a reasonable assumption of what is causing the delays?
    2. Is there a setting in the dmskrnl.cfg file to set the time for the purge pass to run?
    3. We are thinking of setting the limit to 0 to make the cache size limitless for a test period, will this prevent the purge pass from running?
    4. Would setting the cache limit to a lower value help minimize the delays we are seeing?
    5. Would setting the purgebatchsize to a lower value help?
    6. Any recommendations/suggestions on.
    Thanks for any comments/suggestions.
    • Sign in to reply
    • Cancel
    • Michael McCarty
      Michael McCarty Fri, Jun 22 2012 1:52 PM
      It does sound like the purge pass is at the very least participating in the problem.  The very large number of empty folders may be a contributing factor, as the purge process must recurse down into each folder as it searches for purge candidates. Could you try deleting those empty folders ?
      Regarding your other questions:
      2. You can set the "PurgeInterval" dmskrnl.cfg setting under the [Cache] section. The allows you to specify the interval, in seconds, between cache purge executions.
      3. Yes, setting this value to 0 will turn off the purge process.
      4. Doubtful - I still think it's the number of empty folders that is the culprit here.
      5. See #4 above
      HTH
      Mike
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Bob Hanson
      Offline Bob Hanson Fri, Jun 22 2012 2:29 PM in reply to Michael McCarty
      Thank you for your responses, very much aprreciated.  We see the delay on the server but are not sure what is causing them.  We did set the limit to 0 and it did not appear to stop the delays so we are looking elsewhere.   I will delete the empty folders also and making plans to upgrade to Server 2008 R2 to see if that helps.
      • Cancel
      • Sign in to reply
      • Cancel
    • Kevin van Haaren
      Offline Kevin van Haaren Thu, Jun 28 2012 8:57 PM in reply to Michael McCarty
      what happens if you set the purge inteval to 0 and the cache fills to the limit setting?
      • Cancel
      • Sign in to reply
      • Cancel
    • dominic SEAH
      dominic SEAH Sat, Feb 15 2014 7:35 AM in reply to Kevin van Haaren
      bump.... what happened next? What are the optimal settings?
      • Cancel
      • Sign in to reply
      • Cancel
    • Dean Lyon
      Offline Dean Lyon Wed, Feb 19 2014 1:52 PM in reply to dominic SEAH
      We have increased our
      Limit = 8000
      to
      Limit = 20000 (20Gb).
      However, to my konwledge there is only one situation where you interact exclusivly with the caching server and that is on check out with a file that is cached and not updated on the main server.
      Are you experiencing these delays in that situation?
      Did you try turning Delta Transfer off? if  you are transfering large Bitmap files that are not compressable then that would take time to compress and decomparess for not much effect.
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
