Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Tittleblock integration to which Layout?
    • Sign In
    • Replies 8 replies
    • Subscribers 58 subscribers
    • Views 4541 views
    • Users 0 members are here
    • AutoCad
    • projectwise ss3
    • integration
    Jens Brandt
    Jens Brandt over 11 years ago
    Hi
    I am trying to set up a tittleblock intergration for AutoCAD files, and I am (sadly) well aware that ProjectWise will only sync with one of the layouts in a dwg with multiple layouts, asuming that each layout has an appropriate tittleblock. (ProjectWise SS3 and AutoCAD 2011)
    But what I do not understand, is which layout ProjectWise syncs with?
    I have a testfile with 3 layouts (Drawing1, Drawing2 and Drawing3), and each layout has a tittleblock. I did a Attribute Bulk Update, and ProjectWise was updated with the Attributes from the first layout, (Drawing1). Fine, so it is the first layout in the file, that ProjectWise syncs with. -I then moved Drawing3 to the front of the line, by simply dragging the layout tab. The layouts were then ordered as follows: Drawing3, Drawing1, Drawing2. I also took care to save the file with Drawing3 as the active layout, and even checked it in and the out again, to make sure, that Drawing3 in fact was the active layout. However, no matter what i did, ProjectWise kept syncing with Drawing1, and not Drawing3. Can annyone explaine to me why?
    Best regards
    Jens
    • Sign in to reply
    • Cancel
    • Scott Turner
      Scott Turner Tue, Jul 24 2012 2:25 AM
      Hi Jen,
      It is probably syncing with the first instance of the block it finds.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Jens Brandt
      Jens Brandt Mon, Jul 30 2012 9:17 AM in reply to Scott Turner
      Hi Scott
      Thank you for your sugestion.
      -Yes kind of expected that to, but how can I predict which instance of the block it finds first?
      The thing is, that if I know which block it syncs with, then I am at least able to understand it and maybe work arround it, but right now I do not get it...
      Jens
      • Cancel
      • Sign in to reply
      • Cancel
    • Scott Turner
      Scott Turner Tue, Jul 31 2012 12:48 AM
      Predicting that may depend a bit on the drawing setup, as in which layout the user selects when inserting the title block.
      I'd expect that it will always find Layout1 first, assuming that there is a title block inserted into it.
      The layouts are, from what I am told, stored in the block definition table within the drawing which is why I'd expect Layout1 to always be found first.  This is making some assumptions, like the user has not manipulated the tab names, added/deleted tabs, etc.
      • Cancel
      • Sign in to reply
      • Cancel
    • Jens Brandt
      Jens Brandt Tue, Jul 31 2012 8:11 AM in reply to Scott Turner
      By "predicting" i was thinking along if I would be able to say, that the layout on the first layout tab would be syncronized from, or that that last open layout would be syncronized from. The assumption that users will not change layout name or order can unfortunately not be made in our company, so there must be something else that determines what layout ProjectWise is getting its syncronized attributes from?
      My fallback plan at the moment is to have different attributes names in the tittleblocks for each layout. That way they may share the attributes the are common accros the layouts and I get all the information I could ever want in ProjectWise, but the problem is, that peoble will almost certainly mess it up the order of the layouts, and the naming will be of...
      An other thing I stumpled upon: Why do DMSPROPERTIES in AutoCAD not work in the same way as TITTLEBLOCK MODIFY in MicroStation? They do more or less the same (showing the ProjectWise properties for the document), but where TITTLEBLOCK MODIFY also saves its edited values both to ProjectWise, and to the tittleblock, DMSPROPERTIES only updates ProjectWise. Why not have the do exactly the same? (I know it's just one click, but it bugs me!)
      /Jens
      • Cancel
      • Sign in to reply
      • Cancel
    • Indre Barauskaite
      Offline Indre Barauskaite Tue, Aug 7 2012 2:37 PM
      I  have tried to reproduce mentioned Titleblocks behavior, but I got all layouts updated with [AutoCAD 2012 + PW SS4].
      May you try same TitleBlocks update workflow with ProjectWise SS4?
      I have filed Change Request (CR 342121) to update Titleblocks in desing file after PW document attributes dialog is closed. So it would work the same as in MicroStation.
      Best Regards,
      Indre Barauskaite
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
