Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Mixing Managed and Network workspace
    • Sign In
    • Replies 2 replies
    • Subscribers 58 subscribers
    • Views 3748 views
    • Users 0 members are here
    • ProjectWise V8i
    • pw
    • ProjectWise
    Finn Mejding
    Offline Finn Mejding over 11 years ago
    We are using ProjectWise V8i SS3 on CAD files in some of our projects but not in others.
    I want to mix the managed workspace with our network configuration in a way so I am reading the project configuration from the last project loaded in MicroStation outside PW (the active project) and then add on some PW specific variables.
    I have tried adding a PW configuration block at both discipline and user level but when I do that MicroStation starts without a project loaded.
    When I'm not using any managed configuration blocks in PW, MicroStation starts with the "active" project loaded.
    It looks to me that the only way I can re-use the project selection from outside PW is by having no managed configuration blocks n PW.
    Am I right or is there any way to solve this, and don't tell me to import the project configuration because that is not an option :-)
    Finn
    • Sign in to reply
    • Cancel
    • jrathkey
      Offline jrathkey Thu, Jul 19 2012 5:55 PM
      Hello Finn,
      When you run MicroStation locally and change the project MicroStation updates the variable, _USTN_PROJECTNAME, in the user configuration file.  With a Manage Workspace ProjectWise skips the user and project configuration. ProjectWise only uses a minimum configuration, just enough to compile the managed workspace and pass the workspace to the command line used to launch MicroStation.
      To load the last used local project in a Managed Workspace mode you will need to pass the local user configuration file to the managed Workspace.   You can create a Configuration Settings Block in ProjectWise (discipline or user level).  Add a Directive to include the local ucf file..
      %include $(_USTN_USER)$(_USTN_USERNAME).ucf
      This will pass the .ucf file to the MicroStation engine used to compile the workspace and set the _USTN_PROJECTNAME to the last used project.  However,  the project configuration will still be skipped. So you will need to add some logic to grab the local project, *.pcf, file.
      To load the local Project Configuration you can replicate the section from the, msconfig.cfg, in a Configuration Settings Block or add it to you local, *.ucf,  files.
      Example from, msconfig.cfg  (recreate in a discipline or user level CSB or copy and paste to the local, *.ucf, files).
      %ifdef _USTN_PROJECTNAME
      %   if exists ($(_USTN_PROJECT)$(_USTN_PROJECTNAME).pcf)
            _USTN_PROJECTCFG = ${_USTN_PROJECT}$(_USTN_PROJECTNAME).pcf
      %      include $(_USTN_PROJECTCFG) level 3
      %   endif
      %endif
      Once you’re in a Managed Workspace mode you can add ProjectWise specific variables.
      HTH,
      Jeff
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Finn Mejding
      Offline Finn Mejding Mon, Oct 1 2012 2:17 PM in reply to jrathkey
      Thanks Jeff
      I'll try your suggestion and hop I can achieve what I had in mind.
      Finn
      Finn Mejding
      CAD Manager
      Railway and Metro
      COWI
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
