Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum ProjectWise Export/Import Tool is now available for all ProjectWise users
    • Sign In
    • Replies 11 replies
    • Subscribers 61 subscribers
    • Views 16597 views
    • Users 0 members are here
    • Import/Export
    • ProjectWise
    John Schown
    Offline John Schown over 11 years ago
    All,
    For some time Bentley has offered a product known as the ProjectWise Export/Import tool.  This tool enabled the use of XLS spreadsheets as a mechanism for exporting and importing documents from/to ProjectWise datasources.  This tool previously required a separate license to use.
    The ProjectWise Export/Import tool no longer requires a separate license and a new delivery of the tool without the license requirement compatible with ProjectWise V8i (SELECTseries 4) has been posted to Bentley SELECTservices and is available for use by any ProjectWise V8i (SELECTseries 4) user at no additional cost.  In the future, the capabilities provided by the ProjectWise Export/Import tool will be delivered in the standard ProjectWise delivery and downloads.
    Here is a quick description of the capabilities provided by the ProjectWise Export/Import tool:
    The ProjectWise Export/Import tools offer a comprehensive range of features for the bulk import of files and attribute data from external sources into ProjectWise or the bulk export of files and attribute data out of ProjectWise. The ProjectWise Export/Import tools use an Excel spreadsheet as the data interchange format.
    The tools can be used in a number of ways:
    • To export documents and their attributes, so they can be sent to a third party for amendment, and then re-import the amended documents. Amendments to both the documents and their attributes are transferred into the data source.
    • To import documents and their attributes into ProjectWise, which have been exported from a third party program.
    • To import documents and their attributes into ProjectWise for the first time and manually enter the attribute data.
    It is also possible to copy documents between data sources using these tools, but other ProjectWise tools are available to perform this function.
    The ProjectWise Export/Import tools support the transfer of most standard ProjectWise attributes, including versions and the creation of new versions during import, but do not support workflows and states.
    • Sign in to reply
    • Cancel
    Top Replies
    • Suzette Delavega-Edmondson
      Suzette Delavega-Edmondson Thu, Jan 24 2013 4:38 PM in reply to BenQ +1
      John, Does this Export/Import tool support changing the 'general' properties of our files, i.e. Document Name and Description? We sometimes (once every 3 months) have the need to change Document Names…
    • Raul Guerrero
      Offline Raul Guerrero Thu, Jan 31 2019 1:08 PM in reply to Ian Davidson +1
      Hello, Yes, you should be able to change the document name and description with the export import tool.
    • Preeti Jadhav
      Offline Preeti Jadhav Wed, Sep 30 2020 12:04 PM in reply to Suzette Delavega-Edmondson +1
      Hello Suzette, Please check the following link for more details: docs.bentley.com/.../GUID-D7C76056-72F3-4825-BFDE-45B6FEBBED12.html
    • Stuart Nicholson
      Stuart Nicholson Thu, Aug 30 2012 11:53 AM
      Hi John.
      I am still using SELECTseries 3 ProjectWise and the relevant Export/Import Tool.  Do I need to continue to license this separately?  If so, what license is it activated against?  I can see no specific ProjectWise Export/Import license on our select server.  I'm not sure there ever was one.
      Stuart.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • John Schown
      Offline John Schown Thu, Aug 30 2012 1:09 PM in reply to Stuart Nicholson
      There is no reason to change what you are doing now since it is working as is.
      John
      • Cancel
      • Sign in to reply
      • Cancel
    • BenQ
      BenQ Mon, Sep 17 2012 2:57 AM
      Hi John,
      We use PW SS1 (server and client), never bought PWEI license before.
      Would it work if we only upgrade PW client to PW SS4 but server stays at PW SS1?   Any way to try this tool without first upgrading the server to PW SS4?  Thanks.
      • Cancel
      • Sign in to reply
      • Cancel
    • John Schown
      Offline John Schown Mon, Sep 17 2012 2:14 PM in reply to BenQ
      ProjectWise Explorer V8i (SELECTseries 4) is compatible with a SELECTseries 1 Integration Server.  The ProjectWise  Export/Import Tool is specific to the version of ProjectWise Explorer, so I don't see any reason why this combination would not work.
      HTH,
      John
      • Cancel
      • Sign in to reply
      • Cancel
    • BenQ
      BenQ Tue, Sep 18 2012 11:36 PM in reply to John Schown
      As we have not had any PWEI license, we tried using it a few months ago on PWSS1 8.11.7.138 server/client setup using the PWEI 8.11.7.5 version.
      Having seen this post, we would like to revisit the tool using the same setup.
      On load PWE, the tool didn't come up at all apart from the initial license warning dialog.  I have also tried loading PW SS4 8.11.11.111 explorer, the tool didn't come up either.
      I wonder if it is because we never have the PWEI license and it's gone over the 30-day grace period.
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
