Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Export Versions
    • Sign In
    • State Verified Answer
    • Replies 11 replies
    • Subscribers 61 subscribers
    • Views 5417 views
    • Users 0 members are here
    • projectwise version versions ss4 export
    Export Versions
    J03 C:\
    Offline J03 C:\ over 9 years ago
    Good Morning,
    I am trying to find a way to export a document and all its versions. I have tried the usual ways but i only get the newest version. Does anyone have a way to do this? I have searched and found nothing on the subject. Any help would be appreciated.
    Joe C.
    • Sign in to reply
    • Cancel
    • Molly Watts
      0 Offline Molly Watts Wed, Jan 15 2014 1:48 PM in reply to J03 C:\
      I'm not sure I follow, are you looking to export only specific versions of one document?  If so, then no, you cannot.  If you are having trouble getting the correct documents exported, try clearing the export list and start over.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • J03 C:\
      0 Offline J03 C:\ Wed, Jan 15 2014 1:52 PM in reply to Molly Watts
      The second, i am trying to export just the selected docs. I tried as suggested but same result. Its like it doesn't see that list. I am doing a re-install, hopefully that will resolve the issue, as it appears this will do what i want if it works.
      UPDATE: Re-install did not change the outcome.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Molly Watts
      0 Offline Molly Watts Thu, Jan 16 2014 10:29 AM in reply to J03 C:\
      Can you explain the steps you are taking, and what it is that isn't working?  If I undertstand correctly, the wizard isn't acknologing the files you added to the export list?  Are you running the wizard through the start menu, or through export-export list to excel?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • J03 C:\
      0 Offline J03 C:\ Thu, Jan 16 2014 11:22 AM in reply to Molly Watts
      I get into a folder, "Email", i run a search for "Bob", the results show up. I select all the results, right click, export, add to export list, then export list to excel. In the wizard that comes up when i get to the point of selecting files to export i just get the entire contents of "Email" and no where to see the search results.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Molly Watts
      0 Offline Molly Watts Thu, Jan 16 2014 12:44 PM in reply to J03 C:\
      I was finally able to reproduce your issue, it does appear there is a known issue using this process against search results.  The defect number is 28457, which we can add you to if you provide me your contact information.
      Answer Verified By: J03 C:\
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
