When adding a new column to a Managed View via the Administrator module (V8i SS4 8.11.11.567). I will move this new column to the top then apply the changes and close out and when I come back in the newly added column is at the bottom of the Selected columns list. It takes me several tries before PW retains the change. Kind of a pain, does this happen to others?
Part 2 of this same related topic I now open PW Explorer and find the column names shown as the original Attribute name.
Example: Attribute Name = DC_TrackingNumber / Attribute Layout Interface LAYOUT TEXT = Tracking No.)
How can I have it show the proper display name 'Tracking No.'?
I just tried to reproduce it in my 08.11.11.574 admin, basically i made a view then went back into it, added another column, moved it to the top, went out and then back in again and it was still in the same spot. This is what you were doing correct?
What you are describing was actually an old TR that has been fixed, I actually filed it and verified the fix was done.
Yes, if when you went back in the added column was at the bottom not the top you moved it too.
Per your Part 2, the LAYOUT TEXT you use is only used for the interface and the label for the attribute, not a view. Views us the attribute name.
Why are other interface labels showing on columns and some are not?
