Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Revit integration with PW - is anybody using it?
    • Sign In
    • State Not Answered
    • Replies 6 replies
    • Subscribers 59 subscribers
    • Views 4941 views
    • Users 0 members are here
    • BIM
    • BS1192
    • ProjectWise
    • Revit
    Brendan McFarlane
    Offline Brendan McFarlane over 9 years ago
    If anyone has any feedback on using the Revit inegration functionality with PW, I would be glad to hear it. We are planning a large project at the moment and PW has been proposed as the collaboration platform, but as it it our first major BIM project, I am wary about committing to it without testing first on a less critial project.
    Any user experience good or bad would be useful, thanks.
    • Sign in to reply
    • Cancel
    • Paul Patterson
      0 Paul Patterson Tue, Mar 18 2014 11:51 AM
      Morning Brendan,
      We've used ProjectWise to collaborate on multiple projects. One of them being quite large, with a dispersed team between 5 offices.
      Few important items to note;
      1. There is a white paper out there, which describes the do's/don'ts of PW/Revit. It's important to follow this.. largely around the use of worksets, as opposed to on-the-fly element borrowing..
      2. If your project is being done across multiple sites, it's important to evaluate the connection speeds.. we had some serious trouble with this in the early days of the project.. though since resolved.
      3. Model management and federation is key, though this isn't specific to PW..
      4. Proper documentation, and user knowledge is incredibly important..
      I see that you've tagged this with BS1192, which makes me believe that you'll be attempting the whole "shared" process, essentially throwing the latest and greatest over the wall into a shared area, for others to references / pick up.. please be sure to put some serious thought into this. I'm a firm believer in real-time collaboration.. though I'm aware that BS1192 process is taking a slightly different approach.
      Most importantly.. communication, and workflow is key in collaborating on any project, with any software (especially Revit!).. all team members need to understand how they are to work, and why..  this is critical to the success of collaboration.
      There will be some concerns about the lack of on-the-fly element borrowing, and this is understandable.. but trying to achieve that across any WAN is challenging at best..
      Enjoy
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brendan McFarlane
      0 Offline Brendan McFarlane Tue, Mar 18 2014 9:08 PM in reply to Paul Patterson
      Thanks for the info Paul,
      Yes, I have read and digested the white paper, the BS1192 collaboration on the project is a client requirement, and as our core Revit team (Arch/Struct/MEP) is based in one location, the WAN latency issue won't be a problem. I'm also in favour of real-time collaboration, and will be monitoring the progress to see if we need to tweek the workflows to deliver the project more efficiently.
      Is there any impact on Revit file maintenance with using PW, and have you had any file corruption problems?
      Brendan
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Andrea Jackson
      0 Offline Andrea Jackson Wed, Apr 30 2014 4:38 PM
      We recently began using ProjectWise with Revit.  We have experienced a number of hiccups when using Central files.  I can not tell you how many times our central file was became corrupt and had to be recreated from local copies or older versions.  We have experienced quite a bit of lost work and lost time.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Shawn Foster
      0 Offline Shawn Foster Fri, May 9 2014 9:00 AM in reply to Andrea Jackson
      As Paul said, read the white paper first.  Bentley originally created the PW/Revit toolset around Autodesk's own whitepaper on "Best Practices on Revit Worksharing" which is the Workset process, not Element Borrowing.
      The Workset process works very nicely because during borrow/check out is when Revit hits the *.dat files (the eperms, the users, the wperms, the requests).  After the workset checkout, Revit doesn't touch those files until you send the Workset back (or do another).  Those .dat files check out quickly via PW, get written, and get sent back.
      With Element Borrowing, those files are always going all over the place, and it could get tricky.   In a large project, distributed or not, Worksets are the way to go, in my opinion.  I'm sure others may disagree, but I've never had an issue when I was working in Revit using Worksets.
      You probably already have the information in another format, but if you go to midamericacadd.org/2013-conference-presentations , you can download a presentation done at last year's Mid America CADD Community's conference here in Kansas City around ProjectWise and Revit, which includes some nice AVIs.
      HTH,
      Shawn
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Shawn Foster
      0 Offline Shawn Foster Fri, May 9 2014 9:00 AM in reply to Shawn Foster
      Oh, and we are using it as well... :)  "We" being our divisions that use Revit as we are standardized on PW for our work.
      Shawn
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
