DMS_PROJECT Variable Question
I'm using this variable in Projectwise managed workspace and all seems to work jsut fine but when i select Print and get the Print dialog box select the print button, nothing happens, no error message, nothing in message center. If i remove $(DMS_PROJECT(_DGNDIR)) variable from my PW config Block, print works again.
Projectwise SS4 574; Microstation SS3
