Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Attribute Change in Audit Trail
    • Sign In
    • State Verified Answer
    • Replies 8 replies
    • Answers 1 answer
    • Subscribers 59 subscribers
    • Views 4192 views
    • Users 0 members are here
    Shawn Foster
    Offline Shawn Foster over 9 years ago
    Currently (within PW .123), when a user changes an Attribute of a Document, the Audit Trail marks the item as "Sheet Modified", but it doesn't tell me which Attribute changed, or what the new value is....
    Is there a way to display what Attribute changed via the Audit Trail or another mechanism?
    • Sign in to reply
    • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Wed, May 14 2014 5:53 PM
      Hi Shawn unfortunately it does not out of the box configuration. You can have the users comment in the check-in process when they close the application and state the change they made (work around) However audit trail does not go in to details of the specific change.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Shawn Foster
      0 Offline Shawn Foster Thu, May 15 2014 10:01 AM in reply to Ranveer.Basra
      Ranveer:  when you say "out of the box", are you suggesting there is a configuration that can do this, or would it require API programming?
      Shawn
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Fri, May 16 2014 6:52 AM in reply to Shawn Foster
      Hi Shawn,
      I asked development and they stated it is not possible with ProjectWise at this point.
      Ranveer
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dan Williams
      0 Offline Dan Williams Fri, May 16 2014 12:25 PM in reply to Ranveer.Basra
      Shawn,
      You could use the SDK to "capture" what you want to know.
      Basically you would have to use a PreHook and make a copy of the items that you are interested in that might change.  Then in a Posthook, you would compare those items with what they are after the change.  You could then create a comment in the audit trail.
      Answer Verified By: Shawn Foster
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    Reply
    • Dan Williams
      Shawn,
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Fri, May 16 2014 1:55 PM in reply to Dan Williams
      I stand corrected! Thanks Dan
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dan Williams
      0 Offline Dan Williams Sun, May 18 2014 8:57 PM in reply to Ranveer.Basra
      To be clear, this approach will only work for the ProjectWise Explorer client, not for the web client.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Michael McCarty
      0 Michael McCarty Fri, May 30 2014 4:17 PM in reply to Dan Williams
      Actually, I think if you hook AAHOOK_UPDATE_LINK_DATA, and install and register your customization on the web server, this will work for the web server as well.  Not confirmed, I'll dig in a little more.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Shawn Foster
      0 Offline Shawn Foster Fri, Jun 6 2014 1:22 PM in reply to Michael McCarty
      Interesting...thanks!
      Shawn
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
