Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Change Attribute
    • Sign In
    • State Verified Answer
    • Replies 4 replies
    • Subscribers 58 subscribers
    • Views 2322 views
    • Users 0 members are here
    • Attributes
    Change Attribute
    Gerald Piotrowski
    Offline Gerald Piotrowski over 9 years ago
    I need some advice on the best way to achieve the follow task. Any and all comments are greatly appreciated.
    What I need to do is this, set the value of one attribute based off the parsed value of a different attribute.  For example if I have a attribute called "Sht Ref No" I want to parse its value "CG-101" to come up with "CG". Then I want to set the vlaue of "Index Seq. No" to "3.3".
    Gerald Piotrowski
    • Sign in to reply
    • Cancel
    • David Nicholson
      0 Offline David Nicholson Wed, May 28 2014 8:13 AM
      Gerald,
      Peter Willmen kindly responded to a similar question I had only recently
      You could try the following as a SELECT update function:-  SELECT Left('$Sht Ref No$',2)
      Not sure what you mean by:  Then I want to set the vlaue of "Index Seq. No" to "3.3".   Can you provide more explanation?
      Regards,  David
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • David Nicholson
      Gerald,
      Regards,  David
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gerald Piotrowski
      0 Offline Gerald Piotrowski Wed, May 28 2014 11:38 AM in reply to David Nicholson
      David,
      The parsed information from the "Sht Ref No" tells me what Disciple I am dealing with, and then from there I need to update/set the attribute "Index Seq. No" to a predefined number (see table below).
      So based on the table below, if the parsed information from "Sht Ref No" is "G-" the the value for "Index Seq. No" would be "1.0" or if the parsed information from "Sht Ref No" is "H-" the the value for "Index Seq. No" would be "2.0".
      Discipline
      Designator
      Index Seq. No
      Description
      Content
      General
      G-
      1.0
      All General
      All or any portion of subjects in the following
      Level 2 Designators
      GC
      1.1
      General Contract
      Phasing, schedules, contractor staging areas, fencing, haul routes, erosion control, temporary and special requirements
      GI
      1.2
      General Information
      Drawing index, code summary, symbol legend, orientation maps
      GR
      1.3
      General Resource
      Photographs, soil borings
      Hazardous Materials
      H-
      2.0
      All Hazardous
      Materials
      Level 2 Designators
      HA
      2.1
      Asbestos
      Asbestos abatement, identification, or containment
      HC
      2.2
      Chemicals
      Toxic chemicals handling, removal, or storage
      HL
      2.3
      Lead
      Lead piping or paint removal
      HP
      2.4
      PCB
      PCB containment and removal
      HR
      2.5
      Refrigerants
      Ozone depleting refrigerants
       So I am looking for advice on the best way to achive the result (ie Lookup table, or just a SQL statement). Hopefull this explains it a little better.
      Gerald Piotrowski
      Gerald Piotrowski
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Peter Willmen
      0 Offline Peter Willmen Thu, May 29 2014 4:18 AM in reply to Gerald Piotrowski
      Gerald,
      Personally I would use a SQL Stored Procedure rather than a SQL statement as it is more efficient and manageable (from a DB perspective)
      Whichever option you choose you will still need the lookup values in a format that you can query. I would suggest creating a new lookup environment for this.
      Your SQL statement would then be something like this:-
      SELECT IndexSeq from ENV_LOOKUP where Designator = Left('$Sht Ref No$',2)
      You could also auto-populate other attributes (e.g. description, content) from the same lookup table if you require
      Hope that is of some help
      Pete
      Answer Verified By: Gerald Piotrowski
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Gerald Piotrowski
      0 Offline Gerald Piotrowski Thu, Jun 5 2014 4:56 PM in reply to Peter Willmen
      Pete and David,
      Thanks for the information it is greatly appreciated.
      Gerald
      Gerald Piotrowski
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
