Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum PW Web Server & Active X
    • Sign In
    • State Verified Answer
    • Replies 11 replies
    • Answers 1 answer
    • Subscribers 61 subscribers
    • Views 6607 views
    • Users 0 members are here
    Neil Norberg
    Offline Neil Norberg over 9 years ago
    How do you get the Web Server to prompt clients to install the Active X?
    • Sign in to reply
    • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Mon, Jun 30 2014 2:43 PM
      Hi Neil.
      In the Implementation Guide there is a whole section that imply to all the configuration you need for Active X install: These are settings that are mandatory for successful workflow via the web. Now in the past I have also see if there is a prior version of a WebServer Active X then removing that from the IE browser setting and uninstalling it from the client machine will prompt you for the new version (install).
      Hope that helps,
      Ranveer
      Answer Verified By: Ranveer.Basra
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Neil Norberg
      0 Offline Neil Norberg Mon, Jul 7 2014 1:37 PM in reply to Ranveer.Basra
      I believe we have figured out the issue.  We have IE 11 which I do not think is supported.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ranveer.Basra
      0 Offline Ranveer.Basra Mon, Jul 7 2014 3:20 PM in reply to Neil Norberg
      Great! Correct IE 11 is not supported  nor is 64bit browsers.
      • Cancel
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Jeff Burrill
      0 Offline Jeff Burrill Wed, Jul 23 2014 2:50 PM in reply to Ranveer.Basra
      Ranveer - do you have any idea when IE 11 and/or 64 bit will be supported?
      Please note that I post here on a voluntary basis and am not a Bentley employee.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robert Biggar
      0 Offline Robert Biggar Tue, Aug 19 2014 7:58 AM in reply to Jeff Burrill
      I'll Second that question...we just moved to IE 11 and the browser is not working correctly. Any info on when the fix (be it new active x installs or new server software) will be available?
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
