Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum Deploy Workflow Change to Existing Folders
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 58 subscribers
    • Views 3756 views
    • Users 0 members are here
    Neil Norberg
    Offline Neil Norberg over 9 years ago
    Made document security changes to workflow state in Adminstrator.  Existing folders with this workflow don't reflect the changs.  New folders do.  For existing folders I've tried removing and replacing the workflow and removing and replacing the workflow as a project resource.
    please help
    • Sign in to reply
    • Cancel
    • Peter Willmen
      0 Offline Peter Willmen Tue, Jul 15 2014 10:44 AM
      Neil,
      The workflow security settings in PW Administrator only apply 'default' or 'seed' settings for new folders. They do not change any settings for folders already assigned to a workflow.
      I would recommend using the csv/excel import functions from the 'Access Control' tab in PW Explorer but this does need some experimentation with the depth levels to apply. It can also wipe out any folder permissions already assigned. Try it on a test folder structure or system first!
      Hope that helps
      Answer Verified By: Neil Norberg
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Neil Norberg
      0 Offline Neil Norberg Tue, Jul 15 2014 10:54 AM in reply to Peter Willmen
      Thank you Peter.  Not the answer I was hoping for but I suspected was it.  I'll try plan B
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ian Emery
      0 Offline Ian Emery Wed, Jul 16 2014 9:05 AM
      Dear Neil,
      If you change the workflow state security your changes should be seen by any existing document using that workflow state as soon as the changes are saved to the database
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Jeff Burrill
      0 Offline Jeff Burrill Thu, Jul 17 2014 2:35 AM in reply to Ian Emery
      I agree with Ian. If you modify any of the security settings of state(s) in a workflow applied to a folder, that will take effect immediately and there is no need to re-apply anything. You might need to logout of the datasource to see the difference, but that would be the most you would have to do.
      In addition to workflow security, you can also apply additional specific folder and/or document security to a folder. Combined, that is the "real" security that applies ("real" being the term Bentley uses in the drop-down selection). If you look at a folder's properties, you can see if this is the case. It should also tell you if it the folder is inheriting any of the security settings.
      In your case, I suspect existing folders that didn't seem to be affected by your workflow security change have additional security settings, but newly created folders do not, which would explain the behavior you are seeing.
      Please note that I post here on a voluntary basis and am not a Bentley employee.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ian Emery
      0 Offline Ian Emery Fri, Jul 18 2014 8:13 AM in reply to Jeff Burrill
      I like Jeff's suggestion about the additional security settings.
      Remember there is folder security, file security and workflow-state security and a precidence as to which of the 3 is applied in which order. There is a white paper on projectwise security and how it is appiled in the bentley site. - I would agree with Jeff you are probably applying security in several projectwise settings and seeing the end result.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
