Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise Design Integration Forum MicroStation Managed WS in PW
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 61 subscribers
    • Views 2076 views
    • Users 0 members are here
    BenL
    Offline BenL over 9 years ago
    Hi All,
    I'm just starting down the PW path......
    I have imported a managed WS. I read in older documentation I could set it up so that the WS is copied to the users local drive when they open a model or drawing.
    Can someone please point me in the right direction to get this going in SS4 please?
    Thanks in advance.
    Can
    • Sign in to reply
    • Cancel
    • Paul Patterson
      0 Paul Patterson Fri, Jul 25 2014 8:52 AM
      Morning!
      Assuming that you've got the workspace imported correctly.. adding it to a project/folder is rather simple.
      Simple example: You want to add that workspace at the project level.
      Right click the project folder, select the 'Workspace' tab, double click the level in which your workspace was defined (Project in my case), select your workspace, and press Ok.
      It's really that simple.
      To test - place a dgn in one of the child folder of the project, open it up.. and you should see the dialog for gathering workspace files etc.
      Easy as pie (though I don't think I've ever baked a pie?)
      Enjoy,
      Paul
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • BenL
      0 Offline BenL Sat, Jul 26 2014 2:15 AM in reply to Paul Patterson
      Paul, many thanks for getting back to me. I believe I have my workspace imported properly.
      I'm however no seeing the options you are. Am I even in the right spot ? Sorry, very new to PW so thanks for the patience.
      • View
      • Hide
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Paul Patterson
      0 Paul Patterson Mon, Jul 28 2014 12:03 PM in reply to BenL
      Ben,
      You just need to change the workspace "Type" to "Managed".. then your workspace config block will show up.
      Hope that helps,
      Paul
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
