ProjectWise PowerShell Module Requests
This is the post so you the users can request features to be placed inside of the ProjectWise PowerShell Modules.
Parents Reply
  • The program is not just for running PowerShell cmdlets it has a few things in it. It was a bit of a hobby / quick tools to help with a few things and as all programs go it kind of kept getting bigger.
    I'm not doing anything special when running VS, its just running in standard mode (not as admin). I haven't tried running the exe to see if it works, i would assume if the issue occurs debugging? I'll try to run the exe and see if its any different.
