Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Questions about New-PWLogin...
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 65 subscribers
    • Views 2502 views
    • Users 0 members are here
    • powershell
    • PWPowerShell
    • ProjectWise PowerShell Modules
    John Story
    Offline John Story over 5 years ago
    • Did this replace Open-PWConnection? Unclear, guessing yes since the function cannot be found and is not recognized.
    • Trying to use New-PWLogin, I get denied a connection. If I turn on "UseGui" and check SSO on the login dialog, I get the error shown below.
    Last Error 58502
    Cannot login to the datasource
    User is not an administrator.
    • Are only PW Admins able to make a connection to the PW Datasource using the PowerShell functions?
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Mon, Jan 15 2018 4:49 PM +1
      Both are still supported as far as I know. Open-PWConnection * comes with PWPS module in PW Administrator * does not require admin New-PWLogin * comes with PWPS_DAB * requires admin
    • Kevin van Haaren
      0 Offline Kevin van Haaren Mon, Jan 15 2018 4:49 PM
      Open-PWConnection
      New-PWLogin
      * requires admin
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Wed, Jan 24 2018 2:31 PM
      If you are not seeing Open-PWConnection, chances are the PWPS module has not been installed. It is available via the Connect Edition of the ProjectWise Administrator.  Using New-PWLogin requires that the user account is a member of the administrator group.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • John Story
      0 Offline John Story Wed, Jan 24 2018 3:55 PM in reply to Brian Flaherty
      Got this, see a similar reply I did moments ago in another thread.
      Do you have a command line exe install for "pwadm100002265en.exe" to just get that PWPS portion from the PW Admin Installer?
      I need to put the PWPS umbrella on multiple machines so I can have user driven scripts with SSO pass-thru to update given files based on a scripted location.
      Manually installing everything on multiple machines is going a pain...the "Windows Management Framework", the PWPS_DAB and security bypasses, the PW Admin PWPS, etc... lots of manual bits to get a machine going with PWPS in general...
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
