When viewing a datasource's statistics in ProjectWise Administrator there are 2 dates shown. One is the date/time the database statistics were last updated, the other the date the projectwise statistics were last updated.
If I do a Get-PWStatistics there are 2 stats returned, LAST_UPDATED and LastUpdated
LAST_UPDATED is an integer that works out to be the number of seconds since 1/1/1970. LastUpdated is a date/time. At first I thought one of these was the database statistics and the other projectwise statistics update times but that doesn't seem to be the case.
(Get-Date -Date "1/1/1970 00:00:00").AddSeconds((Get-PWStatistics).LAST_UPDATED) returns the same date/time as LastUpdated (just in UTC time instead of the server time zone)
So my question is - am I correct that LastUpdated is just the date/time representation of LAST_UPDATED (adjusted for local time)?
And if I am correct - is there a way to retrieve the Database Statistics Update date/time? If not, can it be added?
Hey Kevin, I have updated this cmdlet so it will now return the Database (Database statistics last updated). Look for it in a future release of the PWPS_DAB module.
Hey Brian, was this going to be in the 1.5.4.0 just released? I'm not seeing it. output below is from 32-bit PW, i tried 64-bit as well.
[ADMIN][Scripts] >new-pwlogin "HNTB CBS" True [ADMIN][Scripts] >$stat = Get-PWStatistics -IgnoreLastLoginCount [ADMIN][Scripts] >$stat DatasourceName : pw-int.hntb.org:CBS LastUpdated : 5/4/2018 1:00:14 AM TotalFileSize : 95710530241 ACCESSCONTROL_COUNT : 346 AFP_FPROP_DOCS_PROCESSED : 0 AFP_FPROP_DOCS_PROCESSING : 19 AFP_FPROP_DOCS_UNPROCESSED : 0 AFP_FTR_DOCS_PROCESSED : 27069 AFP_FTR_DOCS_PROCESSING : 6 AFP_FTR_DOCS_UNPROCESSED : 6 AFP_THUMB_DOCS_PROCESSED : 27059 AFP_THUMB_DOCS_PROCESSING : 12 AFP_THUMB_DOCS_UNPROCESSED : 0 ATTRIBUTE_COUNT : 332 AUDIT_COUNT : 184325 AVG_ATTRIBUTES_PER_ENV : 30 AVG_AUDIT_RECS_PER_FOLDER : 2 AVG_DOCS_PER_FOLDER : 9 AVG_DOC_FILE_SIZE : 3610350 AVG_FOLDER_DEPTH : 6 AVG_REFERENCE_ATTACHMENTS : 3 AVG_USERS_PER_GROUP : 4 CHKL_REC_COUNT : 1772 DEPARTMENT_COUNT : 7 DOCS_NOT_PROCESSED : 0 DOCS_PROCESSED : 27059 DOCS_PROCESSING : 10 DOCS_WITHOUT_THUMB : 0 DOCS_WITH_FPROPS_COUNT : 6621 DOCS_WITH_THUMB : 12118 DOC_COUNT : 27069 EMPTY_FOLDER_COUNT : 1614 ENVIRONMENT_COUNT : 11 FOLDER_COUNT : 4378 GROUP_COUNT : 17 ITEMS_WITH_AUDIT_RECS : 9015 LAST_UPDATED : 1525413614 MASTERFILE_COUNT : 549 MAX_ATTRIBUTES_PER_ENV : 139 MAX_AUDIT_RECS_PER_FOLDER : 1454 MAX_DOCS_PER_FOLDER : 1253 MAX_DOC_FILE_SIZE : 2001098435 MAX_FOLDER_DEPTH : 15 MAX_REFERENCE_ATTACHMENTS : 25 MAX_USERS_PER_GROUP : 8 MIN_ATTRIBUTES_PER_ENV : 1 MIN_AUDIT_RECS_PER_FOLDER : 0 MIN_DOCS_PER_FOLDER : 1 MIN_DOC_FILE_SIZE : 0 MIN_FOLDER_DEPTH : 1 MIN_REFERENCE_ATTACHMENTS : 1 MIN_USERS_PER_GROUP : 1 ODS_CLASS_COUNT : 40 ORPHANED_THUMB_COUNT : 743 POPULATED_FOLDER_COUNT : 2764 PROJECT_COUNT : 4342 PROPERTY_COUNT : 238 QUERY_COUNT : 23 RICHPROJECT_COUNT : 36 STATE_COUNT : 19 STORAGE_COUNT : 7 THUMB_COUNT : 12861 USER_COUNT : 38 USERS_INACTIVE_07 : 0 USERS_INACTIVE_30 : 0 USERS_INACTIVE_60 : 0 USERS_INACTIVE_90 : 0 USERS_INACTIVE_120 : 0 VIEW_COUNT : 18 WORKFLOW_COUNT : 7 Description : ProjectWiseStatistics Name : ProjectWiseStatistics [ADMIN][Scripts] >Get-VersionReport Powershell 32-bit Name Version ---- ------- PowerShell 5.1.14409.1005 CLR 4.0.30319.42000 IniFunctions 0.0 MenuFunctions 0.0 Microsoft.PowerShell.Management 3.1.0.0 Microsoft.PowerShell.Utility 3.1.0.0 PackageManagement 1.0.0.1 PowerShellGet 1.0.0.1 Pscx 3.3.2 PWPS 0.0.0.6 PWPS_DAB 1.5.4.0 PWPS_KvH 1.0 UsefulFunctions 1.0
It should have been included. Let me verify. Sorry for the confusion.
Hey Brian, I'm still not seeing this. What property name should it show up as?
> $stats=Get-PWStatistics -IgnoreLastLoginCount > $stats DatasourceName : pw-int.hntb.org:CBS LastUpdated : 5/18/2018 12:05:19 AM TotalFileSize : 95721951483 ACCESSCONTROL_COUNT : 346 AFP_FPROP_DOCS_PROCESSED : 0 AFP_FPROP_DOCS_PROCESSING : 19 AFP_FPROP_DOCS_UNPROCESSED : 0 AFP_FTR_DOCS_PROCESSED : 27071 AFP_FTR_DOCS_PROCESSING : 6 AFP_FTR_DOCS_UNPROCESSED : 9 AFP_THUMB_DOCS_PROCESSED : 27064 AFP_THUMB_DOCS_PROCESSING : 12 AFP_THUMB_DOCS_UNPROCESSED : 0 ATTRIBUTE_COUNT : 332 AUDIT_COUNT : 184301 AVG_ATTRIBUTES_PER_ENV : 30 AVG_AUDIT_RECS_PER_FOLDER : 2 AVG_DOCS_PER_FOLDER : 9 AVG_DOC_FILE_SIZE : 3610234 AVG_FOLDER_DEPTH : 6 AVG_REFERENCE_ATTACHMENTS : 3 AVG_USERS_PER_GROUP : 4 CHKL_REC_COUNT : 1774 DEPARTMENT_COUNT : 7 DOCS_NOT_PROCESSED : 0 DOCS_PROCESSED : 27064 DOCS_PROCESSING : 10 DOCS_WITHOUT_THUMB : 0 DOCS_WITH_FPROPS_COUNT : 6625 DOCS_WITH_THUMB : 12118 DOC_COUNT : 27074 EMPTY_FOLDER_COUNT : 1613 ENVIRONMENT_COUNT : 11 FOLDER_COUNT : 4379 GROUP_COUNT : 17 ITEMS_WITH_AUDIT_RECS : 8969 LAST_UPDATED : 1526619919 MASTERFILE_COUNT : 549 MAX_ATTRIBUTES_PER_ENV : 139 MAX_AUDIT_RECS_PER_FOLDER : 1472 MAX_DOCS_PER_FOLDER : 1253 MAX_DOC_FILE_SIZE : 2001098435 MAX_FOLDER_DEPTH : 15 MAX_REFERENCE_ATTACHMENTS : 25 MAX_USERS_PER_GROUP : 8 MIN_ATTRIBUTES_PER_ENV : 1 MIN_AUDIT_RECS_PER_FOLDER : 0 MIN_DOCS_PER_FOLDER : 1 MIN_DOC_FILE_SIZE : 0 MIN_FOLDER_DEPTH : 1 MIN_REFERENCE_ATTACHMENTS : 1 MIN_USERS_PER_GROUP : 1 ODS_CLASS_COUNT : 40 ORPHANED_THUMB_COUNT : 743 POPULATED_FOLDER_COUNT : 2766 PROJECT_COUNT : 4343 PROPERTY_COUNT : 238 QUERY_COUNT : 23 RICHPROJECT_COUNT : 36 STATE_COUNT : 19 STORAGE_COUNT : 7 THUMB_COUNT : 12861 USER_COUNT : 38 USERS_INACTIVE_07 : 0 USERS_INACTIVE_30 : 0 USERS_INACTIVE_60 : 0 USERS_INACTIVE_90 : 0 USERS_INACTIVE_120 : 0 VIEW_COUNT : 18 WORKFLOW_COUNT : 7 Description : ProjectWiseStatistics Name : ProjectWiseStatistics
Which version of the PWPS_DAB module are you currently running? I just installed the latest (1.5.8.0) and I get the following. Notice DBLastUpdated.DatasourceName : BMF-WS2016:BMF_PWLastUpdated : 4/18/2018 10:00:43 AMDBLastUpdated : 3/21/2018 9:26:36 PMTotalFileSize : 782142451ACCESSCONTROL_COUNT : 129AFP_FPROP_DOCS_PROCESSED : 0AFP_FPROP_DOCS_PROCESSING : 0AFP_FPROP_DOCS_UNPROCESSED : 733AFP_FTR_DOCS_PROCESSED : 0AFP_FTR_DOCS_PROCESSING : 0AFP_FTR_DOCS_UNPROCESSED : 733AFP_THUMB_DOCS_PROCESSED : 0AFP_THUMB_DOCS_PROCESSING : 0AFP_THUMB_DOCS_UNPROCESSED : 733ATTRIBUTE_COUNT : 69AUDIT_COUNT : 8224AVG_ATTRIBUTES_PER_ENV : 23AVG_AUDIT_RECS_PER_FOLDER : 1AVG_DOCS_PER_FOLDER : 4AVG_DOC_FILE_SIZE : 1248422AVG_FOLDER_DEPTH : 3AVG_REFERENCE_ATTACHMENTS : 3AVG_USERS_PER_GROUP : 1CHKL_REC_COUNT : 129DEPARTMENT_COUNT : 0DOCS_NOT_PROCESSED : 733DOCS_PROCESSED : 0DOCS_PROCESSING : 0DOCS_WITHOUT_THUMB : 0DOCS_WITH_FPROPS_COUNT : 0DOCS_WITH_THUMB : 0DOC_COUNT : 733EMPTY_FOLDER_COUNT : 205ENVIRONMENT_COUNT : 3FOLDER_COUNT : 368GROUP_COUNT : 2ITEMS_WITH_AUDIT_RECS : 3435LAST_UPDATED : 1524060043DBLAST_UPDATED : 1521681996MASTERFILE_COUNT : 126MAX_ATTRIBUTES_PER_ENV : 39MAX_AUDIT_RECS_PER_FOLDER : 200MAX_DOCS_PER_FOLDER : 108MAX_DOC_FILE_SIZE : 89722613MAX_FOLDER_DEPTH : 8MAX_REFERENCE_ATTACHMENTS : 18MAX_USERS_PER_GROUP : 1MIN_ATTRIBUTES_PER_ENV : 4MIN_AUDIT_RECS_PER_FOLDER : 0MIN_DOCS_PER_FOLDER : 1MIN_DOC_FILE_SIZE : 193MIN_FOLDER_DEPTH : 1MIN_REFERENCE_ATTACHMENTS : 1MIN_USERS_PER_GROUP : 1ODS_CLASS_COUNT : 38ORPHANED_THUMB_COUNT : 0POPULATED_FOLDER_COUNT : 163PROJECT_COUNT : 356PROPERTY_COUNT : 0QUERY_COUNT : 41RICHPROJECT_COUNT : 12STATE_COUNT : 31STORAGE_COUNT : 1THUMB_COUNT : 0USER_COUNT : 2USERS_INACTIVE_07 : 4USERS_INACTIVE_30 : 4USERS_INACTIVE_60 : 4USERS_INACTIVE_90 : 4USERS_INACTIVE_120 : 4VIEW_COUNT : 2WORKFLOW_COUNT : 4Description : ProjectWiseStatisticsName : ProjectWiseStatistics
