Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Get-PWDocumentsBySearch : Not logged in as a ProjectWise Administrator.
    • Sign In
    • State Verified Answer
    • Replies 25 replies
    • Answers 3 answers
    • Subscribers 70 subscribers
    • Views 7251 views
    • Users 0 members are here
    Gavin Chapman
    Offline Gavin Chapman over 5 years ago
    When running a simple 'Get-PWDocumentsBySearch' command
    $Docs = Get-PWDocumentsBySearch -SearchName "$ProjectFolderPath\$pdfSearchName" -filename '%.pdf' -GetAttributes
    I now get an error, which I never used to get before
    I am using the Open-PWConnection method because I don't want to use an administrator login -Admin parameter, the New-PWLogin method requires an administrator login and I don't want to use the GUI because this is on an automatic scheduled task.
    ModuleType Version    Name
    Binary     1.5.5.0    PWPS_DAB
    Any assistance will be greatly appreciated
    Kind regards Gavin Chapman
    • Sign in to reply
    • Cancel
    Top Replies
    • John Story
      Offline John Story Mon, May 14 2018 8:27 AM in reply to Gavin Chapman +4
      I hope this is a typo or requires some other context... Similarly, for PWPS_DAB we use a "Service" account that is granted elevated rights to given Projects on a Project by Project basis, and it is definitely…
    • Duncan Taylor
      Offline Duncan Taylor Tue, May 15 2018 8:32 AM in reply to John Story +3
      A ditto for me. This will result in the PowerShell functions becoming absolutely useless. I am using PowerShell to produce dashboard reports from ProjectWise data (which are not available from Project…
    • Gavin Chapman
      Offline Gavin Chapman Mon, May 14 2018 5:58 AM in reply to Brian Flaherty +2
      Hi Brian We have a 'Batch' user account that we use for certain automated tasks, these automated tasks manipulate data in one way or another, this account doesn't have admin rights and for certain reasons…
    • Duncan Taylor
      0 Offline Duncan Taylor Tue, May 15 2018 8:32 AM in reply to John Story
      A ditto for me. This will result in the PowerShell functions becoming absolutely useless. I am using PowerShell to produce dashboard reports from ProjectWise data (which are not available from Project Insights) and as this is just reporting data that is in ProjectWise and not changing anything, does not need Admin login rights. I don't have an Admin log in, and so far have not needed one.
      Please do not make the assumption that PowerShell is only / should only be used for server administration tasks - there is far more to its capabilities and use than that.
      Given Bentley have pushed PowerShell at us as a way of accomplishing our dashboard reporting (which were very well received at the recent ProjectWise LEARN Conference) for accessing information that ProjectWise can't otherwise, if you are not prepared to open these functions back up again to non-Admin users, then I guess I will just have to push my reporting requirements back to Bentley to solve.
      • Cancel
      • Vote Up +3 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Paul Patterson
      0 Offline Paul Patterson Tue, May 15 2018 9:26 AM in reply to Brian Flaherty
      Brian - +1 for including the Restricted Admins
      • Cancel
      • Vote Up -1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Peter Willmen
      0 Offline Peter Willmen Tue, May 15 2018 10:05 AM in reply to Brian Flaherty
      As an Administrator for a number of large systems I am in full support of the Admin only usage.
      The PowerShell cmdlets are not yet supported under the SELECT agreement so they should be used in a controlled manner. I have seen a major outage caused by somebody using a script - even though they were an Admin user!
      That said, I can see the benefits of having a tiered approach to security - e.g. PowerShell Admins & PowerShell Users with read-only functions available to the latter - as well as an Audit trail record indicating that an action was run from PowerShell but not at the expense of slowing down the fast development cycle we are getting today.
      You can see from the amount of discussion in the Communities pages and at Bentley events that the PowerShell functions have become essential tools for administering ProjectWise and for me personally save many hours of work on repetitive tasks.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dave Brumbaugh
      +1 Offline Dave Brumbaugh Tue, May 15 2018 1:42 PM
      Well, we've never really looked at the use case of non-admin users using the PowerShell cmdlets. We actually looked at the use of Open-PWConnection without admin credentials allowing you to use the PWPS_DAB cmdlets to be a bug. I'm pretty convinced non-admin users shouldn't be using PowerShell to manipulate the datasource, and I've made various commitments to internal parties that we wouldn't permit non-admin access.  That said, we will support Restricted Admins in the next release.
      Answer Verified By: Gavin Chapman
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Dave Brumbaugh
      0 Offline Dave Brumbaugh Tue, May 15 2018 1:43 PM in reply to Dave Brumbaugh
      Next release will be in a day or two.  We tend to have pretty short release cycles for PWPS_DAB.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
