Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Get-PWDocumentsBySearch : Not logged in as a ProjectWise Administrator.
    • Sign In
    • State Verified Answer
    • Replies 25 replies
    • Answers 3 answers
    • Subscribers 70 subscribers
    • Views 7288 views
    • Users 0 members are here
    Gavin Chapman
    Offline Gavin Chapman over 5 years ago
    When running a simple 'Get-PWDocumentsBySearch' command
    $Docs = Get-PWDocumentsBySearch -SearchName "$ProjectFolderPath\$pdfSearchName" -filename '%.pdf' -GetAttributes
    I now get an error, which I never used to get before
    I am using the Open-PWConnection method because I don't want to use an administrator login -Admin parameter, the New-PWLogin method requires an administrator login and I don't want to use the GUI because this is on an automatic scheduled task.
    ModuleType Version    Name
    Binary     1.5.5.0    PWPS_DAB
    Any assistance will be greatly appreciated
    Kind regards Gavin Chapman
    • Sign in to reply
    • Cancel
    Top Replies
    • John Story
      Offline John Story Mon, May 14 2018 8:27 AM in reply to Gavin Chapman +4
      I hope this is a typo or requires some other context... Similarly, for PWPS_DAB we use a "Service" account that is granted elevated rights to given Projects on a Project by Project basis, and it is definitely…
    • Duncan Taylor
      Offline Duncan Taylor Tue, May 15 2018 8:32 AM in reply to John Story +3
      A ditto for me. This will result in the PowerShell functions becoming absolutely useless. I am using PowerShell to produce dashboard reports from ProjectWise data (which are not available from Project…
    • Gavin Chapman
      Offline Gavin Chapman Mon, May 14 2018 5:58 AM in reply to Brian Flaherty +2
      Hi Brian We have a 'Batch' user account that we use for certain automated tasks, these automated tasks manipulate data in one way or another, this account doesn't have admin rights and for certain reasons…
    • Scott Turner
      0 Offline Scott Turner Tue, May 29 2018 12:41 AM in reply to Brian Flaherty
      Limiting this to admin only is, in my opinion, going to severely restrict the benefit of the tool.  There are an increasing number of project users that have little choice than to use PS to extract data that is then used to feed Power BI.  In addition to this, three are several projects that we have that are joint-venture, and PS is used by JV partners to extract copies of the data for their records.
      In both of these examples I have zero intention of making these users administrators, and neither do I want to be doing these tasks myself.
      I feel that PS should simply respect the access of the user running the script, unless there is some other reason why this will not work.
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Tue, May 29 2018 6:44 AM in reply to Scott Turner
      Scott, your comments and opinion are duly noted. However, please refer to Dave Brumbaugh's, previous response.
      • Cancel
      • Vote Up -1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dave Brumbaugh
      0 Offline Dave Brumbaugh Tue, May 29 2018 9:12 AM in reply to Scott Turner
      Not saying it can't be done.  Just wondering about the wisdom of it.  Are there really "normal" users that want to use PowerShell to interact with ProjectWise? Unless everyday users have gotten a LOT more sophisticated than the last time I managed a bunch of them, I just don't see it happening.
      That said, I could see a dedicated group called "PowerShell Users" or some such that an administrator would have to add you to and a switch to force a non-admin login. Will discuss with the team.
      We really appreciate all the good ideas coming from this group.
      Dave
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mick Inkster
      0 Offline Mick Inkster Tue, May 29 2018 3:19 PM in reply to Dave Brumbaugh
      Dave, my thinking behind this is that if I could use Powershell on an external companies datasource with only the limited access rights that I had, it would be very useful. I use it on my own datasource as a full administrator, but I do not know too many companies that will allow an external party to have even restricted admin rights to the datasource that they manage.
      I realise the original Powershell was aimed at Administrators and most cmdlets were designed to help with managing the server side of their tasks, but this module has expanded into documents and allowed us to run tasks that would otherwise take a long time.
      Mick
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • John Story
      0 Offline John Story Wed, May 30 2018 11:54 AM in reply to Dave Brumbaugh
      Dave, It's not that "normal users" want to use PWPS really for anything... I doubt they would "get it", since we are (I am) having so much trouble trying to do "simple" tasks. As stated before a few times, all I want is to use PWPS to do the following:
      1. "Periodic" Bulk Import/Export/Sync Operations on Rich Projects using a "Project Administrator" Authenticated Account under a Rich Project, where the Account has Rights to the Project, but is not PWAdmin (similar to a tool we "purchased" from Bentley that now does not function on some Projects running as PWAdmin, and is now depreciated). Audit Trail is not an issue, files may be Synced multiple times per hour to keep Data "fresh".
      2. "Real-Time" Semi-Automated file Imports/Exports in the Users Context (on their behalf where possible and allowed), by insertion of code fragments into Workflows, like take a externally created ISOGEN ISO as DWG and get it back into PW, into the correct folder, updating the previous version, in the context of the user as finishing sub-application, so they do not have to wait for Item #1 above to process. The user does not need to be involved, just has to own the process... Also makes the Audit Trail more valuable.
      We are trying to make it easier for users to use and interact with ProjectWise on "Hybrid" Projects (Some Apps and Files Integrated into PW, but always other Apps that are not PW Friendly still outside) where we would like the Focus to be PW.
      Failure to do these means the Project Costs go up as the manual interactions go up...
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
