Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Can PW PS be used as a non-PW Administrator?
    • Sign In
    • State Suggested Answer
    • Replies 2 replies
    • Answers 1 answer
    • Subscribers 66 subscribers
    • Views 1179 views
    • Users 0 members are here
    • powershell
    • projectwise admin
    • ProjectWise
    Matthew Ashby
    Offline Matthew Ashby over 4 years ago
    I am a long time MicroStation (MS) user, but a brand new ProjectWise (PW) user. My current PW work tasks are being performed as a non-PW administrator for a PW workspace/datasource hosted by a state DOT. Here's my question: As a non-PW administrator, is it still possible to use some of the PW PS Cmdlets? For example, I am interested in discovering a method for easily checking-out multiple DGN files to my local computer, which I can then work on, and then when I am done, using an easy method to check-in all these DGN files.
    Matt
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Sat, Jan 19 2019 9:21 AM +2
      Not in a way that you'll really be able to use it in this scenario. Pwps_dab can be run as non-admin but still requires you to be in a Projectwise group called "PowerShell Users" to do so. it sounds…
    • Brian Flaherty
      Offline Brian Flaherty Mon, Jan 21 2019 2:58 PM in reply to Kevin van Haaren +1 suggested
      Excellent reply Kevin.
    • Kevin van Haaren
      0 Offline Kevin van Haaren Sat, Jan 19 2019 9:21 AM
      it sounds like you're trying to bypass using ProjectWise Explorer to open your files. Don't do this, for several reasons.
      1. Your reference files won't work. Projectwise uses a file GUID for file attachments, bypassing PWE means these won't work.
      2. Attaching references won't work. See #1 above, any new attachments won't use the proper GUID and will be broken for other users.
      3. Files checked out by powershell  still go in their dms folder in the working directory. Navigating that by hand is painful.
      4. If the DOT uses a managed workspace it won't work with this workflow.
      instead some of the workflow you mention can be handled with the Local Document Organizer. It's under the Tools menu (and a button on the toolbar). It'll show you all your checked out files in one list. You can open any one of them by double clicking. Or you can select multiple files and check them all in, or do an update server copy on them.
      for checking out files, if the files are in one folder you can select multiple files, right-click and select check-out. If they're scattered about in different folders it's a bit harder. You could create personal saved searches to help. For example a search where you were the last person to edit the file. Or a search where the file name matches your files. Etc...
      • Cancel
      • Vote Up +2 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    Reply
    • Kevin van Haaren
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Mon, Jan 21 2019 2:58 PM in reply to Kevin van Haaren
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
