Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Have the email notifications for this community stopped sending?
    • Sign In
    • State Verified Answer
    • +1 person also asked this people also asked this
    • Replies 11 replies
    • Subscribers 66 subscribers
    • Views 3949 views
    • Users 0 members are here
    Nathan Banks
    Offline Nathan Banks over 4 years ago
    My collegues and myself havent recieved any email notifications since early January.
    I get the non-stop sales/advertising emails about every Bentley product there is, but the communities notifications have stopped.
    Just wondering if this has happened to any one else or if i need to get my IT to look into it.
    • Sign in to reply
    • Cancel
    Top Replies
    • Kevin van Haaren
      Offline Kevin van Haaren Sun, Feb 10 2019 10:42 AM +1
      I got an email notification for this message. possible it's getting rejected by your email server?
    • Jesse Dringoli
      Offline Jesse Dringoli Mon, Feb 25 2019 1:53 PM in reply to Kevin van Haaren +1
      Hello Nathan/Kevin/Jan, We (Bentley) are working on a fix to this SPF issue. Thank you for your patience.
    • Jan Ĺ legr
      Offline Jan Ĺ legr Tue, Feb 26 2019 1:00 AM in reply to Jesse Dringoli +1
      Hi Jesse, Jesse Dringoli said: We (Bentley) are working on a fix to this SPF issue. Thank you for your patience. thanks for the information, because it seems to getting worse, not better. I do not…
    • Jan Ĺ legr
      0 Offline Jan Ĺ legr Tue, Feb 26 2019 1:00 AM in reply to Jesse Dringoli
      Hi Jesse,
      I do not understand a bit "are working", because to change SPF is 5 minutes work and this change is published to the rest of Internet in a few hours. Nothing complicated, I do it for domains I own from time to time also.
        Jan
      Bentley Accredited Developer: iTwin Platform - Associate
      Labyrinth Technology  |  dev.notes()  |  cad.point
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Kevin van Haaren
      0 Offline Kevin van Haaren Tue, Feb 26 2019 4:36 PM in reply to Jan Ĺ legr
      hahaha, welcome to the world of enterprise level network management. The trick isn't (mostly) making the change, it's knowing what to change the field too.
      I checked the email headers on notices i've been getting from the communities. They're routed from telligent.com. That means their SPF (and if they add DKIM and DMARC) info has to come from telligent. More than likely telligent has hundreds of servers. Hopefully telligent has a published SPF field that Bentley can add to their SPF record "just use this SPF record from this company over here..." and when telligent updates their records bentley won't be caught out again.
      Next, they've probably also outsourced their DNS. Which means once they have what the records should actually be, they need to file a change request with their DNS company. Depending on who that is it may take awhile.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Jan Ĺ legr
      0 Offline Jan Ĺ legr Thu, Feb 28 2019 1:17 PM in reply to Kevin van Haaren
      Hi Kevin,
      I agree that when a company has become enterprise, simple things start to be often complicated. Especially when there is nobody who is responsible for a particular area / service / issue ... or he share more responsibilities as often in Bentley.
      On the other hand, to change DNS settings is simple task that is done in one place through web interface and is proposed to the rest of DNS servers automatically. I do the same when I am informed about necessary change despite of I know very little about DNS technical details. For my domains it's as simple "for Office 365 / Exchange server, copy paste this TXT record, the same for my webs and A and CNAME records).
      So to me it looks silly that such basic configuration with potentially huge impact as SPF can be left wrong for longer than a day. Somebody does not do his work right ... but maybe such person does not exist.
      With regards,
        Jan
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Nathan Banks
      0 Offline Nathan Banks Fri, Mar 1 2019 5:17 AM in reply to Jan Ĺ legr
      Changing records on my domain is a quick process too, but I'm sure a large company would need to go through a change process to make changes in a controlled way.
      There appears to be an issue around the QA. These basic things shouldn't be happening if the correct checks were done. Lots of issues like this continue to slip out the front door, which leads to a lot of wasted time fault finding for them (then being told there's a defect already filed. lol).
      Fun times.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Jesse Dringoli
      +1 Offline Jesse Dringoli Fri, Mar 1 2019 4:09 PM in reply to Nathan Banks
      Hi all - the SPF (email) issue has been resolved, and a better system has been put in place to prevent future occurrences. Apologies for the inconvenience. For those of you who have had trouble with emails - please let me know if you continue to have problems.
      Jesse Dringoli
      Bentley Systems, Inc.
      Answer Verified By: Nathan Banks
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
