Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Update document Description using CSV file
    • Sign In
    • State Verified Answer
    • Replies 2 replies
    • Subscribers 65 subscribers
    • Views 730 views
    • Users 0 members are here
    • Update-PWDocumentProperties
    Qadeer Hussain
    Offline Qadeer Hussain over 4 years ago
    I need to update value in Document Description attribute of multiple documents. Each document description value is different so I want  to use a PowerShell Script using Update-PWDocumentProperties. Can someone help me to create PowerShell script to update document Description of multiple documents when description value is different for each document.
    I have tried to use following script but it is not updating the Document description even I am not getting any error.
    $Objects = import-csv “C:\UpdateAttributes.csv” –header doc1,Description -delimiter '|'
    ForEach ($Object in $Objects){
    $doc1 = $($Object.doc1)
    $Description = $($Object.Description)
    $doc = Get-PWDocumentsBySearch -FolderPath "Projects\Project\800 Training\TEST" -DocumentName $doc1
    Update-PWDocumentProperties -InputDocument $doc
    Get-PWDocumentsBySearch -FolderPath "Projects\HE565628_Oxford_to_Cambridge_Expressway\800 Training\TEST" | Foreach -MemberName $Description
    • Sign in to reply
    • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Fri, Apr 5 2019 7:20 AM
      Hi Qadeer,
      Give the following a try. Should do what  you need.
      $Objects = Import-Csv 'C:\UpdateAttributes.csv' -Header doc1,Description -Delimiter '|'
          # Get the document object to update.
          $doc = Get-PWDocumentsBySearch -FolderPath "Projects\Project\800 Training\TEST" -DocumentName $Object.doc1 -JustThisFolder
          # Set the value for the description.
          $doc.Description = $($Object.Description)
          # Update the document.
      Answer Verified By: Qadeer Hussain
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Qadeer Hussain
      0 Offline Qadeer Hussain Fri, Apr 5 2019 7:46 AM in reply to Brian Flaherty
      Many thanks - it is working like a sweat Pie.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
