Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Exporting entire project with reference link updates
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 66 subscribers
    • Views 1032 views
    • Users 0 members are here
    • Export
    • projectwise admin
    • PWPowerShell
    Gary Mansager
    Offline Gary Mansager over 4 years ago
    We have a project where we want to export from PW to a file system, and rewrite the reference links to be maintained within that file system. We have attempted to use Send-to with the "Update documents to use local paths for references and links" toggle checked. However, it does not correctly update the links to references in other folders. We also tried to run the Import/Export wizard. While this does update the reference links correctly, it does not export all folders and substructure within some folders. For example, this is a 84GB project, 24GB did not export, and some folders merely contained PDFs. We are quickly running out of options. Can a PowerShell cmdlet accomplish this goal?
    • Sign in to reply
    • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Wed, May 1 2019 4:25 PM
      I don't believe we currently have anything available via PowerShell.  You could accomplish this task in multiple steps.   Use the Import/Export wizard to export and update the references for your design files and use PowerShell to export the remaining folders/files, etc.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mark Kovach
      0 Offline Mark Kovach Wed, Nov 13 2019 6:53 AM
      Not sure if this is a true consideration in your case but the exported document path(s) cannot exceed the Windows character limit 255.
      Mark Kovach
      SNC-Lavalin
      Design/CDE System Integrator
      Information Technology Services
      Engineering, Design and Project Management
      ProjectWise CONNECT Edition | PowerShell | Power Automate
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Mark Kovach
      0 Offline Mark Kovach Wed, Nov 13 2019 7:41 AM in reply to Mark Kovach
      Actually after I wrote this I remembered that it (Export feature) should notify you if the path exceeds the limitation so probably not what's happening to you.
      This would be a cool feature (cmd-let) to be added or updated to include relinking references via Powershell.
      Mark Kovach
      SNC-Lavalin
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
