Hello everyone,
For those of you at the conference, this was the dashboard I showed in my presentation and for those not at the conference, this is a dashboard on performance monitoring inside of ProjectWise using PowerShell. Please find the attached documents to getting started with setting up performance monitoring on your system. There is a PowerShell script that needs to be run on some kind of scheduled task at the various locations you want to test, the template for the PowerBi report and a setup document to help you link the results from your script with PowerBi. For any questions or discussion please post to this thread. Enjoy!
Marty
UPDATE March 16, 2020
ProjectWise_Performance_Report_1.0.7zProjectWise_Performance_Report_Example_2.0.zip ProjectWise_Performance_Dashboard_1.0.zip
Hey everyone, if you're writing to SQL or want a datatable as the output, use the -OutputType "DataTable" switch in the Get-PWPerformanceReportData cmdlet. Example below.
$PWPerformanceReportVariables = @{ Connection = "Home Wifi"; Location = "Melbourne, Victoria"; ConnectingViaCache = "False" Datasource = "decide-pwce-aus.bentley.com:decide-pwce-aus-010" ProjectWiseUserName = "PWReportUser" ProjectWisePassword = (ConvertTo-SecureString -String PWPassword -AsPlainText -Force); OutputType = "DataTable"; } $PerformanceData = Get-PWPerformanceReportData @PWPerformanceReportVariables -Verbose
While testing an export to SQLLITE I did the following, just sharing might find it useful..
$scriptFolder = (([System.IO.Directory]::GetParent($MyInvocation.MyCommand.Path)).FullName) $PWPerformanceReportVariables = @{ Connection = "Office LAN"; Location = "Melbourne, Victoria"; ConnectingViaCache = "True"; Datasource = "decide-pwce-aus.bentley.com:decide-pwce-aus-010"; ProjectWiseUserName = "PWUserName"; ProjectWisePassword = (ConvertTo-SecureString -String PWPassword -AsPlainText -Force); OutputType = "DataTable"; } $PerformanceDataset = Get-PWPerformanceReportData @PWPerformanceReportVariables -Verbose foreach ($Table in $PerformanceDataset.Tables) { #create a new datatable to populate with the performance data $dt = New-Object System.Data.Datatable ($Table.TableName) #add the columns to the datatable. We can use the property names of the properties object as our column names # Get a list of the performance properties. $PWperformanceProperties = $Table | Get-Member -MemberType Property # Add columns to the datatable for each of the properties in $docProperties foreach ($property in $PWperformanceProperties){ $dt.Columns.Add($property.Name) | Out-Null } #create a new datarow, loop through the performance data and populate the row, and then add the row to the datatable # Create New Datarow $dr = $dt.NewRow() # Populate Datarow with performance values foreach ($column in $dt.Columns) { $dr[$column.ColumnName] = $Table.$($column.ColumnName) } # Add new row to the datatable $dt.Rows.Add($dr) $SQLLITE = @{ SourceDataTable = $dt; OutputFolder = $scriptFolder; OutputFileName = "PW_Performance.sqlite"; } #Export dataset to a SQLLITE database Export-DataTableToSQLiteDB @SQLLITE -Append }
Thanks for sharing.
