Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Define Interface when using Export-PWDocument with export of metadata
    • Sign In
    • State Verified Answer
    • Replies 4 replies
    • Subscribers 65 subscribers
    • Views 683 views
    • Users 0 members are here
    • attribute
    • powershell
    • Export
    • pwps_dab
    • Export-PWDocuments
    Robin Björnklint
    Offline Robin Björnklint over 3 years ago
    Hi!
    In Projectwise we have multiple Interfaces within the same Environment. Does anyone know of there is a way to define which interface should be used when exporting documents with metadata using Export-PWDocuments?
    I did not see any possiblity to define this in the cmdlet and I can't find any other cmdlet that defines this. I also checked if it mattered which Interface was set in Projectwise but that didn't seem to matter.
    • Sign in to reply
    • Cancel
    Top Replies
    • Brian Flaherty
      Offline Brian Flaherty Tue, Dec 10 2019 10:53 AM +1 verified
      The metadata exported will contain ALL attributes. We do not have a method to only include those attributes available within an interface.
    • Brian Flaherty
      +1 Offline Brian Flaherty Tue, Dec 10 2019 10:53 AM
      Answer Verified By: Robin Björnklint
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Reject Answer
      • Cancel
    • Robin Björnklint
      0 Offline Robin Björnklint Wed, Dec 11 2019 4:00 AM in reply to Brian Flaherty
      I was hoping for that but it doesn't seem to be the case for me. What I get in the excelsheet is three tabs: General, XXXXX_basic_environment and Audit trail.
      XXXXX_basic_environment contains custom attributes and it is these that seems to be affected by the interface used/defined. I get the custom attributes contained within a specific Interface and not all Interfaces. Unfortunately for me it doesn't give me attributes based on the Interface I want.
      I realize that I probably should have mentioned this in my original post.
      Edit: I just want to say that you have done a fantastic work with the PowerShell-module. It opens so many doors and gives so many options for creating a more automated work environment.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robin Björnklint
      0 Offline Robin Björnklint Thu, Dec 19 2019 4:05 AM in reply to Robin Björnklint
      I get the same result when I use Get-PWDocumentsBySearch with -GetAttributes. It only gives me the CustomAttributes for one specific Interface. Can I define this Interface or define that it should get ALL attributes? I am using the latest version of PWPS_DAB 1.16.2.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robin Björnklint
      0 Offline Robin Björnklint Tue, Jan 7 2020 6:25 AM in reply to Robin Björnklint
      I did get all the metadata without realizing it.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
