PowerShell Examples not installed
It appears the PowerShell example folder is no longer being installed.  I tried 2 installs with version 10.00.03.140 but C:\Program Files (x86)\Bentley\ProjectWise\bin\PowerShell\pwps\Examples\ folder is not installed on either system.  I then tried to Modify the installation of both ProjectWise Administrator and Client and both believe everything is installed.  Where else could I find the (previously?) delivered examples?  The path above was copied from the readme file and I pasted it, minus the Examples portion, in Windows Explorer to make sure I was getting to the correct location.  There was an example script and associated spreadsheet which accomplishes almost exactly what I need so I was hoping to use it as a starting point but don't have access to a previous install
