Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum bug Get-PWDocumentsBySearch -SearchName extremely slow
    • Sign In
    • State Not Answered
    • Replies 7 replies
    • Subscribers 70 subscribers
    • Views 1681 views
    • Users 0 members are here
    GChapman
    Offline GChapman over 3 years ago
    when using an older version of pwps_dab (1.5.15.0) and running the Get-PWDocumentsBySearch -SearchName function process, it completes in seconds, however when running the same function using a newer version of pwps_dab (1.16.3.0), its taking minutes. This is reproducible at any time, I can demonstrate if required, can this be looked into?
    Major Minor Build Revision
    1 5 15 0
    Start date/time.. 2020-02-27_06-21-06
    Number of docs: 21
    End date/time.. 2020-02-27_06-21-26
    1 16 3 0
    Start date/time.. 2020-02-27_06-21-39
    Number of docs: 21
    End date/time.. 2020-02-27_06-25-22
    New-PWLogin -UseGui
        #Folder Locations
        $ProjectFolderPath = "some folder\project"
        $SearchName = "Project Models"
        write-host "version pwps_dab: "
        (Get-Module "PWPS_DAB" | Where ModuleType -eq "Binary").Version
        $Date = (get-date -Format "yyyy-MM-dd_HH-mm-ss")
        write-host 'Start date/time.. ' $Date
        #get documents by search
        $Docs = Get-PWDocumentsBySearch -SearchName "$ProjectFolderPath\$SearchName"
        write-host "Number of docs: " $Docs.count
        write-host 'End date/time.. ' $Date
    Undo-PWLogin
    • Sign in to reply
    • Cancel
    • Dave Cole
      0 Offline Dave Cole Thu, Feb 27 2020 4:07 PM
      Functionality was added after 1.5 to report on cmdlet usage.  This has resulted in tremendous slowdown for some cmdlets.
      communities.bentley.com/.../install-pwps_dab-on-server-with-blocked-access-to-internet
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gavin Chapman
      0 Offline Gavin Chapman Fri, Feb 28 2020 12:28 AM
      Hi Dave
      The performance is so bad with some of our queries that I have, downgraded the version to the older version, just so that it can complete processing in a reasonable time.
      Install-Module pwps_dab -MaximumVersion 1.5.15.0 -Verbose
      This is however not ideal as I am now unable to use some of the newer functions. If the reporting on cmdlet usage is the culprit, then it seriously needs to be looked into by the developers Frowning2
      Kind regards
      Gavin Chapman
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robert McMillan
      0 Offline Robert McMillan Fri, Feb 28 2020 12:39 AM
      Hi Gavin, out of interest have you tried the latest module versions as well? There have been improvements made to the performance of a number of cmdlets over the past few months. Latest version is 1.19.1.0
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Gavin Chapman
      0 Offline Gavin Chapman Fri, Feb 28 2020 12:53 AM
      Hi Robert
      Unfortunately yes, I have tried the latest pwps_dab (1.19.1.0), and have the same extremely slow result.
      1      19     1      0
      Start date/time..  2020-02-28_07-48-12
      Number of docs:  21
      End date/time..  2020-02-28_07-52-01
      Kind regards
      Gavin Chapman
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Jülide Kers
      0 Offline Jülide Kers Tue, Mar 3 2020 1:36 AM
      [deleted]
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
