Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum PWPS_DAB Version Check
    • Sign In
    • State Verified Answer
    • Replies 6 replies
    • Subscribers 66 subscribers
    • Views 1632 views
    • Users 0 members are here
    Dave Cole
    Offline Dave Cole over 3 years ago
    I am using this to check the version of PWPS_DAB before running a script.  Is there a better way to do this?
    $LocalDabModuleVersion = Get-Module -Name PWPS_DAB -ListAvailable
    $LocalVersionString = $LocalDabModuleVersion.Version.ToString().Replace(".","")
    If($LocalVersionString -lt "12110")
        Write-Host "PWPS_DAB 1.21.1.0 or newer required to run this script." -ForegroundColor Cyan
        Write-Host
    }else{
        Write-Host "PWPS_DAB" $LocalDabModuleVersion.Version "found. Script will run." -ForegroundColor Cyan
        Write-Host
    I can see potential issues with this method.  For example, when PWPS_DAB 2.0.0.0 is released.
    Thanks.
    • Sign in to reply
    • Cancel
    Top Replies
    • Dan Williams
      Offline Dan Williams Wed, Apr 22 2020 3:08 PM +1 verified
      You might want to check out the #Requires statement documented here: https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.core/about/about_requires?view=powershell-5.1 I tried it with…
    • Dave Cole
      Offline Dave Cole Wed, Apr 22 2020 3:47 PM in reply to Dan Williams +1
      Thanks! Tweaking it a bit, this will work in ISE #Requires -Modules PWPS_DAB, @{ModuleName="PWPS_DAB";ModuleVersion="1.21.1.0"} Adding ModuleVersion specifies the minimum version needed to run.
    • Brian Flaherty
      0 Offline Brian Flaherty Wed, Apr 22 2020 2:58 PM
      Are you trying to ensure the latest version is installed?
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dave Cole
      0 Offline Dave Cole Wed, Apr 22 2020 3:02 PM in reply to Brian Flaherty
      I want to ensure that a minimum required version is installed.  This may not be the most up-to-date version.
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Dan Williams
      +1 Offline Dan Williams Wed, Apr 22 2020 3:08 PM
      I tried it with this script:
      #https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.core/about/about_requires?view=powershell-5.1
      #Requires -Version 5.1
      #Requires -Modules @{ ModuleName="PWPS_DAB"; RequiredVersion="1.21.1.0" }
      write-host 'hello world'
      #Get-Module -Name PWPS_DAB -ListAvailable
      Be aware that if you try this with the run command in a PowerShell ISE session, it is ignored.  Just save your file and run that from the command prompt.
      Here's where it works OK:
      When versions are OK.
      And where it doesn't:
      Missing required version.
      Thanks for asking, I learned something new (to me) today!
      Answer Verified By: Dave Cole
      • Cancel
      • Vote Up +1 Vote Down
      • Sign in to reply
      • Verify Answer
      • Reject Answer
      • Cancel
    • Dave Cole
      0 Offline Dave Cole Wed, Apr 22 2020 3:47 PM in reply to Dan Williams
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Robert McMillan
      0 Offline Robert McMillan Wed, Apr 22 2020 6:56 PM in reply to Dan Williams
      This can also be achieved with a -MinimumVersion or -RequiredVersion with Import-Module. Works in PowerShell ISE as well.
      Import-Module -Name 'PWPS_DAB' -MinimumVersion '1.20.2.0' -ErrorAction Stop
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
