Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum How to set Datasource security for the root / top folder ?
    • Sign In
    • State Not Answered
    • Replies 3 replies
    • Subscribers 65 subscribers
    • Views 725 views
    • Users 0 members are here
    • powershell
    • datasource
    • ProjectWise
    • ProjectWise PowerShell Modules
    Ludovick
    Offline Ludovick over 3 years ago
    I need to change 250+ datasource parameters for the security of the root folder.
    Manually, I go to pw administrator, select my project/datasource, right-click Properties, then edit 'folder security' and 'document security'
    Can i do it with powershell ?
    I know Update-PWFolderSecurity but it seems to be for subfolders
    Is it with Set-PWDatasourceSetting  ? Does some know the options for document security and folder security ?
    thanks
    Ludovick
    • Sign in to reply
    • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Fri, May 22 2020 11:13 AM
      The Update-PWFolderSecurity should do what you need. Ensure you are passing the parent folder object.  If you need any assistance feel free to contact me at brian.flaherty@bentley.com.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Brian Flaherty
      0 Offline Brian Flaherty Fri, May 22 2020 11:32 AM in reply to Brian Flaherty
      After receiving some clarification from Ludovick, he would like to set the datasource level access control. Below is my response. If you feel you would benefit from this capability, let us know.  We can always add new cmdlets. Slight smile    We are up to 484.
      The following was my response:
      "Understood. We do not have any cmdlets for manipulating the datasource level access control.  It seems to me that would be something done only occasionally and can easily be accomplished via the ProjectWise Administrator.
      I am going to post this response in the Bentley Communities site.  If other users feel they could benefit from having the ability to configure the datasource level access control, then we could potentially add some cmdlets."
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    • Ludovick
      0 Offline Ludovick Fri, May 22 2020 11:49 AM in reply to Brian Flaherty
      thanks for your quick help
      Ludovick LAGREVOL
      Projectwise Administrator
      • Cancel
      • Sign in to reply
      • Verify Answer
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
