Bentley Communities
Bentley Communities
  • Site
  • User
  • Site
  • Search
  • User
ProjectWise
  • Product Communities
ProjectWise
ProjectWise PowerShell Extensions Forum Version 1.21.5.0 of PWPS_DAB just posted to the PowerShell Gallery
    • Sign In
    • Replies 10 replies
    • Subscribers 65 subscribers
    • Views 2246 views
    • Users 0 members are here
    Dave Brumbaugh
    Offline Dave Brumbaugh over 3 years ago
    We just posted version 1.21.5.0 of the #PWPS_DAB #PowerShell module for #ProjectWise to the PowerShell Gallery. To install, from a 64-bit Admin session of PowerShell v5 run: [Net.ServicePointManager]::SecurityProtocol=[Net.SecurityProtocolType]::Tls12, Uninstall-Module PWPS_DAB -AllVersions -Force, Install-Module PWPS_DAB. VERY IMPORTANT NOTE: This PowerShell Module is not covered under your SELECT Agreement and is not supported via your contractual support channels. Support is only available via the BE Communities site ( communities.bentley.com/.../projectwise-powershell-extensions-forum ).
    • Sign in to reply
    • Cancel
    • Kevin van Haaren
      Offline Kevin van Haaren Tue, Jun 9 2020 11:08 PM
      2020-06-09 Version 1.21.5.0
      Changed cmdlets
      • Update-PWFolderSecurityByUserListSwapWithWorkflow
        • made some (possible) performance improvements.
      • Import-PWDocuments
        • added -SuppressOutput switch which may have performance benefits.
      • New-PWRichProject (and related)
        • fixed a bug where a bad list of properties to update would cause the process to end before moving the new project to the right spot.
      • Cancel
      • Vote Up 0 Vote Down
      • Sign in to reply
      • Cancel
    • Jonathan Britten
      Offline Jonathan Britten Fri, Jun 12 2020 11:03 AM
      I have attempted to install the PowerShell module PWPS_DAB using the command shown in the original post. The error message states missing expression after ',' Uninstall-Module appears to be invalid or incomplete. Any help would be appreciated. Thank you.
      • Cancel
      • Sign in to reply
      • Cancel
    • Kevin van Haaren
      Offline Kevin van Haaren Sat, Jun 13 2020 6:28 PM in reply to Jonathan Britten
      Not sure what you mean by "the original post". The installation method has changed since the very beginning. Did you follow the instructions in this post?
      https://communities.bentley.com/products/projectwise/content_management/f/projectwise-powershell-extensions-forum/143840/update-we-have-changed-the-way-we-are-delivering-pwps_dab
      • Cancel
      • Sign in to reply
      • Cancel
    • Kevin van Haaren
      Offline Kevin van Haaren Sat, Jun 13 2020 6:28 PM in reply to Kevin van Haaren
      Also Uninstall-Module won't work if you've never installed it before, you can skip that step.
      • Cancel
      • Sign in to reply
      • Cancel
    • Bill Graefe
      Offline Bill Graefe Mon, Jun 15 2020 11:55 AM in reply to Jonathan Britten
      Hmmmm. I suggested that Dave change what he puts from a comma (,) to a semicolon (;) as that would make the two commands actually work if pasted. The other comment about it not being installed should also be valid.
      Bill
      • Cancel
      • Sign in to reply
      • Cancel
    Communities
    • Home
    • Getting Started
    • Community Central
    • Products
    • Support
    • Secure File Upload
    • Feedback
    Support and Services
    • Home
    • Product Support
    • Downloads
    Training and Learning
    • Home
    • About Bentley Institute
    • My Learning History
    • Reference Books
    Social Media
    •    LinkedIn
    •    Facebook
    •    Twitter
    •    YouTube
    •    RSS Feed
    •    Email
