Unable to install PWPS_DAB module
We are trying to install PWPS_DAB. But there below error is coming. We tried it for 32-bit and 64-bit ISE, for both same error is coming.
Install-Module PWPS_DAB -Scope Currentuser -Force
WARNING: Error: Unable to load DLL 'dmscli.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E
at PWPS_DAB.Utility.aaApi_Initialize(Int32 init)
at PWPS_DAB.Utility.InitializePWAPI(Int32 init)
at PWPS_DAB.NewPWLogin.ProcessRecord()
False
New-PWLogin : The type initializer for 'PWWrapper' threw an exception.
At line:1 char:1
+ New-PWLogin
+ CategoryInfo : NotSpecified: (:) [New-PWLogin], TypeInitializationException
+ FullyQualifiedErrorId : System.TypeInitializationException,PWPS_DAB.NewPWLogin
Also the Module Path is present in $env:PSModulePath variable.
Powershell Version -: 5.1.17763.1490
